Hose on the RS500PICTURE WANTED
Old Jul 18, 2007 | 11:25 AM
RS500/364's Avatar
RS500/364
Default Hose on the RS500PICTURE WANTED
the one that goes from the bottom of the rad still pipe
to were the water pump is on the block do samco paul roose do them
Old Jul 18, 2007 | 08:18 PM
RS500/364's Avatar
RS500/364
No one then
Old Jul 18, 2007 | 08:26 PM
rapidcossie's Avatar
rapidcossie
thread doesnt make much sense mate?
RS 500 water hoses are same as any 2wd, so yeas you can get some kind of silicon hose for them.
Old Jul 18, 2007 | 09:32 PM
RS500/364's Avatar
RS500/364
No they ant !!
Old Jul 18, 2007 | 10:43 PM
Mr RS500's Avatar
Mr RS500
The rs500 has quite a few one off water pipes
Old Jul 19, 2007 | 09:10 AM
charlie luciano's Avatar
charlie luciano
If I'm thinking of the correct pipe you are on about the smallish pipe that comes off of the metal pipe that runs along the bottom of the radiator and then goes into the side of the water pump on the engine,
I don't know about a RS500 but I have a pipe that is similar on my car and I obtained it from Graham Goodes, GG part number for my pipe is 1212,
Give them a ring they will more than likely be able to sort you out
Luciano
Old Jul 19, 2007 | 09:40 AM
RS500/364's Avatar
RS500/364
Luciano
That sounds like the one and only that one needed
got a brand new set off samco for sale now as didnt fit FFS
Dont want the GGR one as they faded badly
Old Jul 19, 2007 | 09:59 AM
RS500/364's Avatar
RS500/364
does this look like it do you remember
Old Jul 19, 2007 | 10:09 AM
charlie luciano
No mine looked a bit different, but there again as you know my car is a 4x4 saph, mine is kinda L shaped, will try n sort out a pic later
Luciano
Old Jul 19, 2007 | 10:29 AM
RS500/364's Avatar
RS500/364
Luciano
FFS i bet i got one at the garage with me 4x4 is i should go look and kick his ass to move it
moesin2005
Jan 23, 2022 06:28 PM
rog
Aug 30, 2015 05:32 PM
Dicko&Vacant
Aug 21, 2015 05:59 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
adriansaleem
Aug 3, 2015 11:21 AM
