RadTec Vs Pro Alloy
Old Jul 17, 2007 | 07:21 PM
BlueFiesta85's Avatar
BlueFiesta85
Default RadTec Vs Pro Alloy
well looking into purchasing a intercooler, only prob is the pro alloy one is £400+ new and i believe someone on here is selling a radtec with fans for £340.
so the problem is which one is worth investing into or are they both very similar in terms of performance and getting the best out of the turbo?
Old Jul 17, 2007 | 07:58 PM
gambit's Avatar
gambit
Default intercooler
I ran the pro alloy second generation cooler with added turbo cooler on mine which at the power i was running i would give it 10/10. However if i were to get another intercooler it would only be a grs, i went for the pro alloy as it a class bit of kit and can cope with alot.
Old Jul 17, 2007 | 08:15 PM
105epwr's Avatar
105epwr
i use the radtec which im getting great power etc and run a act gauge and its lovley and cool.nice solid well made bit of kit.
Old Jul 17, 2007 | 08:41 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
GRS all the way. I love Pro Alloys workmanship, but the GRS is certainly doing the business on mine and seems to perform better than the Pro Alloy Gen 2 cooler did.
Old Jul 17, 2007 | 11:40 PM
Noisy Boy's Avatar
Noisy Boy
always hear good things about them grs intercoolers
Old Jul 18, 2007 | 03:16 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
As per Christian, Cant fault Pro's work, there welding is next to none!
GRS for me If I was staying FWD cvh, But as Im going down the ZT RWD Route, i'll be opting for a Pro Alloy one
Old Jul 18, 2007 | 05:47 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
GRS Twin Pass For Me
Old Jul 18, 2007 | 06:32 AM
h460 ugh's Avatar
h460 ugh
grs all the way m8. i had a proalloy I/C and had huge problems with it overheating wen not moveing. hope this helps
Old Jul 18, 2007 | 08:55 AM
BlueFiesta85
is it easy to fit the grs i/c will i have to remove the bonnet catch as it is a very large piece of kit?
Old Jul 18, 2007 | 10:28 AM
TURBO BOY's Avatar
TURBO BOY
The finish on Pro Alloy is second to none however resultswise, GRS for me.
Old Jul 18, 2007 | 11:23 AM
dave_y's Avatar
dave_y
GRS fits perfectly you just need to tilt the rad back slightly with a bracket which comes as part of the intercooler fitting kit.
Then drill a couple of holes in the front panel and your away.
Old Jul 18, 2007 | 11:36 AM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Iv been looking at grs intecoolers, and im sure some one on another thread told me they were £450 plus, but just fount this link
http://www.grsmotorsport.co.uk/ersts2intercoolers.html
It says it £265 for the twin pass, is this the correct one?does it come with a fitting kit which gives you every thing you need to fit it.
Whats difference between twin and single apart from single looking harder to fit with the hoses being opposite sides.
How much do they charge for the slim linke fan?cheers
Old Jul 18, 2007 | 12:03 PM
dave_y's Avatar
dave_y
GRS is £445 all in. that includes 2 x Kenlowe fans.
therefore £90 per fan.
therefore the £265 i'd imagine will come with the fitting kit etc just not the fans.
Old Jul 18, 2007 | 02:51 PM
Christian and Beccy
#1 in Spelling Club
I usually modify the bonnet release lever to make it slightly easier to get to and so it doesn't club the top of the Intercooler.
It is a squeeze, but worth the extra work to get it in IMO.
Old Jul 18, 2007 | 04:47 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
So did the standard cooler
GRS all the way
Old Jul 18, 2007 | 05:38 PM
tomhs123's Avatar
tomhs123
definatly grs mate. never had any problems with it and i think its cheaper than the others!
Old Jul 18, 2007 | 06:57 PM
Puss2's Avatar
Puss2
Formerly know as Puss
GRS on mine working a treat
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
