front cross member
Old Jul 17, 2007 | 07:09 PM
djcossie's Avatar
djcossie
Default front cross member
whats the diff!!!!!!!!!!
beween 2wd and 4wd front crossmembers
Old Jul 18, 2007 | 07:10 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the 2wd one is pressed steel
the 4wd one is aluminium
you can't swap them over as the engine mounts and steering rack locations are different as well as the brake pipe locations on the bolts, the tca holes amongst other things
C2 MAK
Aug 20, 2015 09:46 PM
Graceland
Jul 31, 2015 10:34 AM
