Mid engined, cossie'd, rwd, renault 5! update 27/5/15
engine
2litre 16v 2wd sierra cosworth engine
t3 turbo
bosch 803 injectors
21 psi boost
grp a coil
grp a regulater
grp a headgasket
4x4 inlet manifold
vernier pulleys
huge pace ally radiator
ally swirl pot
ally header tank
2 fans running 2 stage switch + override
2 charge coolers, 2 pumps, 2 swirlpots
huge pace ally pre rad
ally grp a oil breather system
bosch 044 fuel pump
-6 fuel lines and fittings
pro alloy foam filled fuel tank
un1 gearbox
ap cossie/reno clutch
oil cooler
level 8 management
running approx 340 bhp lb/ft
chassis
ford rs200 rear spaceframe
engine/suspension all bolted to cradle
full welded in roll cage tagged to body everywhere and to space frame
std r5 front end upto where rear seat used to start in floor
rear suspension
rs 200 setup inc.
4 coilovers
double wishbones
tie bars
race polybushes
2wd cossie hubs
all adjustable in every direction
front suspension
avo coilovers
race polybushes
r5 hubs with ford stud adapters
brakes
ap 4 pots up front 330 mm discs
wilwood 4 pots at rear 300mm disds
group n corsa bias pedal box (adjustable in dash)
-4 braided lines throughout
hydraulic handbrake
std bodywork outside
fully stripped inside
2 corbeau revolution seats
homemade ally dash housing clocks and relays/fuses
cable gearchange
plastic windows
billet compomotive mo's (very strong (and expensive))
kerb weight under 1000kgs
probably loads ive forgotten, anything u wanna know just ask
I was gonna say it sounds and looks like the RC one, the right colour anyways !
Pics dont work cos RTOC are bummers and want you to pay money to access any of the site
car sounds amazing though, PLEASE PLEASE let us see more !
Spud
Spud
Originally Posted by stu21t
he started it yes, basically put the rear frame in then stopped the build and i finished it
Originally Posted by Porkie
Where u get them fuckin wheels!!!!
Pete..
What a perfect combination,that must be fucking mental
you didn't by any chance have a blue 21t and an M3 gt did you ? and go up the mile on a wednesday ?
cheers
Matt
cheers
Matt
