ecu,s
Old Jul 16, 2007 | 05:29 PM
cossie362's Avatar
cossie362
Default ecu,s
quick question peeps
i currently have an evo6 that i was goin to get re mapped at power engineering but i have just been offered a remapped ecu out of another 6 for 300 pound
now i know nothing about ecus so do i just plug it in and set up the boost controller or shall i let the pros set the car up???????
cheers
Old Jul 16, 2007 | 05:35 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Is the engine spec of his IDENTICAL to yours?
If not I wouldnt even consider it, and TBH even if it is, I still wouldnt do it personally as no doubt there will be differences you arent aware of such as leakdown test results etc.
You cant beat having a map made for YOUR car.
I assume this is an "ecutek" is it?
ECU Monitor Enthusiast
Dont risk it unless you get a pro to check it out first
Old Jul 16, 2007 | 05:44 PM
cossie362's Avatar
cossie362
it is an ecu tek mate
thanks for the advice
il let the pros do there job
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
