sierra temperature guage sending unit.
Old Jul 16, 2007 | 03:26 PM
xr4man's Avatar
xr4man
Default sierra temperature guage sending unit.
does anyone have a part number and a link to where i can order the temperature sender for the temperature gauge in a sierra?
or that would be willing to go pick one up and mail it to me?
Old Jul 16, 2007 | 07:33 PM
AndyPen's Avatar
AndyPen
Default temp sensor
I assume you mean the gauge sender mate - have a new Ford one here so will go check the number Its a cosworth 3dr or Saff 2wd one - is that what you need?
Cheers,
Andy
Old Jul 16, 2007 | 08:01 PM
xr4man's Avatar
xr4man
that what i think i will try. my thoughts are that the gauge clusters are interchangeable between the sierras and the merkurs. so the gauge sender has to have the same properties as the merkur one. the mustang senders over here are only a couple bucks so i figured that the sierra ones couldn't be real expansive either.
Old Jul 16, 2007 | 08:48 PM
AndyPen's Avatar
AndyPen
Default sender
Hi again,
part number is...
FINIS 6145143 sender-temp
... but I think they cost nearly £30 over here I'm afraid
Old Jul 16, 2007 | 11:06 PM
xr4man's Avatar
xr4man
great googly moogly!!!
thanks
i was on the cosworth site and they have the temperature sensor for $52 and teh temperature sender for $3.40. i am looking for the temperature sender i think. so i'm going to order one from them.
Old Jul 20, 2007 | 05:09 PM
gwynny's Avatar
gwynny
where is the gauge sender situated??
Old Jul 20, 2007 | 05:32 PM
AndyPen's Avatar
AndyPen
Front end of the head mate - by the tubo, the wire usually runs over the cam cover to it and fixes with one of those 'top hat' connections... see pic
Old Jul 20, 2007 | 05:36 PM
AndyPen's Avatar
AndyPen
and fitted to a bare head
Old Jul 20, 2007 | 05:37 PM
gwynny's Avatar
gwynny
is it the same on 4wd head andy??
Old Jul 20, 2007 | 06:02 PM
NO 4wd next to CTS sender other side at rear of head.
Old Jul 20, 2007 | 06:16 PM
AndyPen's Avatar
AndyPen
Thanks Tab - should have spotted that
Old Jul 20, 2007 | 06:21 PM
gwynny's Avatar
gwynny
All sorted now folks, thanks!!
Old Jul 20, 2007 | 06:28 PM
xr4man's Avatar
xr4man
yeah that looks like the same style that is on the merkur. i ordered one from cosworth the other day so when it gets here we'll see if it has the same operating range as the merkur. which is 19 ohms on the hot side and 240 ohms on the cold side.
Old Jul 20, 2007 | 06:33 PM
AndyPen's Avatar
AndyPen
Hope it works mate
Old Jul 20, 2007 | 11:01 PM
xr4man's Avatar
xr4man
yeah me too. if it does then there will be scores of merkur owners that can make their temp gauges work again. i just can't believe that someone hasn't tried this already.
nico12
Dec 31, 2015 04:42 PM
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
Bransby
Sep 21, 2015 05:29 PM
