Serviced Passat TDi bloody thing won't start - SORTED
I dd the bit about draining water from the fuel filter and nnow the bloody thing won't start.
How do I prime/bleed it? I've tried a couple of things (taking hoses off and trying to suck through but nothing)
Can anyone help?
thanks
Can anyone help?
thanks
1998 AFN 1.9tdi
I tried Joe's advice, I couldn't take the filter apart so I had to fill it from the drain plug, upside down
Still didn't want to take so I haven't tried to bleed by cracking the inj.
get a 17 or a 19mm spanner on a injector pipe, get the wife or who ever to sit inside with it cranking over and while cranking slacken the injector union nut unitl fuel comes out, it will prob start to try to fire by then try another pipe also if its not quite going yet but it will fire up
lol, just wind it over on the starter, it'll go eventually if you have a good enough battery. vw's are usually quite good at starting up once run dry.
or as said, slacken off the injector pipes and spin it over until diesel comes out then close them again.
easy start or brake cleaner does the trick.fire it down the air intake in short bursts untill it fires. it will sound like its gonna blow up but they never do.
focus 2.0 diesels are the same,right pain in the arse.
bryan
bryan
bryan
bryan
This is what i'd do too!
All sorted, many thanks chaps
After sleeping on it as I was pissed off with it last night, this morning I cracked each of the injector unions in turn whilst the wife turned it over. It fired immediately after a couple of turns once i cracked the first one actually but I cracked all of them one at a time just to make sure.
She now fires on the first turn.
Many thanks
Many thanks
Many thanks
Many thanks
this is what we have to do at work, pretty much everyday with our truck engines
rog
Sep 4, 2015 12:10 PM
if u cant get it out first try
