At last full compression ON ALL BORES. Clap Clap
Old Sep 25, 2004 | 07:26 PM
L33 BYT's Avatar
L33 BYT
Default At last full compression ON ALL BORES. Clap Clap
What a night mare. Think my car does not like Felpro gaskets. Fitted a ford item from PJ motorsport and all is good.
Old Sep 25, 2004 | 07:39 PM
DazC's Avatar
DazC
I didn't think any RST liked Felpro gaskets....
Old Sep 25, 2004 | 07:42 PM
L33 BYT's Avatar
L33 BYT
Had two, in a matter of months.
First was letting water into combustion chamber giving a nice disco smoke effect from the rear. still steam cleaned the valves and pistons for me.
Second one was ok then no compression on 1.
Nice cheap OEM gasket and hey wola. SORTED!!
Old Sep 25, 2004 | 07:48 PM
DazC's Avatar
DazC
Proper Ford gaskets are the ultimate on RST.
Old Sep 25, 2004 | 07:49 PM
L33 BYT's Avatar
L33 BYT
Is there an issue with Felpro then?
Old Sep 25, 2004 | 07:50 PM
DazC's Avatar
DazC
Yes.
They are shit and not designed for a turbo engine.
Old Sep 25, 2004 | 07:53 PM
L33 BYT's Avatar
L33 BYT
Yes.
I was looking at them earlier.
The Ford item I have has (hard to explain) thicker rings on each of the cylinder holes, made of a seperate ring of metal compared to the felpro.
Old Sep 25, 2004 | 07:56 PM
DazC's Avatar
DazC
Fire rings....
I can't remember what a Felpro looks like to be honest but I recall them having been designed for the 1900 normally aspirated engine. I think that was it anyway...
Old Sep 25, 2004 | 08:00 PM
L33 BYT's Avatar
L33 BYT
Well hopefully this will be a long term mend. Stuck a new clutch in too. just need to tighten up some nuts and get the wheels back on then its
TEST DRIVE TIME
Old Sep 25, 2004 | 08:48 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I use NON Genuine (a particular make though) and have for some time!! Dont seem to mind 2 Bar of boost!!
Mark_
14
Jan 16, 2016 05:27 PM
rsguy
44
Sep 29, 2015 03:29 PM
Carlbacciochi
Sep 26, 2015 04:23 PM
