What do you class as high reving ?
Old Sep 25, 2004 | 07:00 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Default What do you class as high reving ?
When driving normally and you boot it, what would class as reving high and not hitting the rev limit ?
4k+ ?
5k+ ?
What do you drive normally at ? changing gears ? etc etc
Old Sep 25, 2004 | 07:03 PM
NUTS RuS's Avatar
NUTS RuS
8300 at the mo as I have dropped the limiter to save some money
Old Sep 25, 2004 | 07:04 PM
TIFF's Avatar
TIFF
Chasing Radders
7000 + is high revving
I usually change about 6500 when out and about
Old Sep 25, 2004 | 07:05 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
i wouldnt say mine is high revving as it is set to 7.2 hard cut
but i change gear at 7k
Old Sep 25, 2004 | 07:07 PM
Adam_BlackRS
Ex Ford Man
Wish i could even rev to 7k
Old Sep 25, 2004 | 07:10 PM
Paul Eggleton's Avatar
Paul Eggleton
My cut is around 6300-6500, when giving it some I take it to 5800-6000.
Paul
Old Sep 25, 2004 | 07:13 PM
Rob's Avatar
Rob
when you have a power band that starts at 1500, and finishes at 6k why rev the nuts off them hear them right and your engine will last forever
Old Sep 25, 2004 | 07:58 PM
Jim Galbally's Avatar
Jim Galbally
whenever i go above above about 4.5k i think thats high! lol
but then my engine only revs to 6 :P
Old Sep 25, 2004 | 08:22 PM
markk's Avatar
markk
10k+
Ginge !'s Avatar
Ginge !
just finding my feet
i rev to 3k when im going to work
i rev the cossie to 7 grand but onlu cause the fooker is sooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooo laggy
Old Sep 25, 2004 | 08:23 PM
Ginge !'s Avatar
Ginge !
but my neighbour has a rvf400 bike and a r1, they rev higher than that
markk's Avatar
markk
BDA baby !!!
Old Sep 25, 2004 | 08:24 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
i call my kart high revving
18k
Old Sep 25, 2004 | 08:49 PM
Bread's Avatar
Bread
How accurate are mk4 escort rev counters?
mine goes well off to about 8000rpm. with kent cv35
1.6 na engine,
Old Sep 25, 2004 | 09:14 PM
zedy's Avatar
zedy
to me high revving is when the valves start stomping, takin it to the limit , but mostly bout 5k+
Old Sep 25, 2004 | 09:16 PM
Jamz's Avatar
Jamz
5.5 - 6k then I get scared and change gear
Old Sep 25, 2004 | 09:20 PM
James Raby's Avatar
James Raby
Anything above 3k will kill your engine (said in Kevin B terms LOL)
Old Sep 25, 2004 | 09:24 PM
Escy's Avatar
Escy
over 7k although i've not taken it above 6k in normal driving yet (hit 8k a few times whilst going sideways)
Old Sep 25, 2004 | 09:30 PM
T28 RST's Avatar
T28 RST
Ok then
6800 for me
Old Sep 25, 2004 | 09:45 PM
wimwerf's Avatar
wimwerf
7k is the max. when i give it some i'll rev to 5.5k (because of the t-3). with the t-34 soon it could even further.
Old Sep 25, 2004 | 11:30 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
mines set at7200 st the minure,
my 1700YB setup was set at 9200
turbo and engine matchup was poor so ditched the 1700cc setup,
current rev limmit is 6900/7000rpm, dont normally hit the limmiter as it slows you down lol.
Old Sep 26, 2004 | 01:36 AM
philc's Avatar
philc
dont really cane the xr3, however the lexus has a slush box so cant really hold it on the limiter, dont stop me trying though
Old Sep 26, 2004 | 01:38 AM
Bread's Avatar
Bread
is there any point me revving over 6500?
its ony a 1.6 lol
cv35 cam, ported, race valve angles(woteva that is)
chipped, light n balanced bottom end, 4 branch + stainless zorst
lightened flywheel????, erst gearbox
power boost valve <-god knows wot that things for
frst fuel pump, all full xr2i EFI loom
al i know its pretty nippy for a 1.6
dead level with saxo vts
Old Sep 26, 2004 | 02:18 AM
Steven_RW's Avatar
Steven_RW
only ever changed gear on the imiter in the evo
every change once hot
RW
Old Sep 26, 2004 | 02:21 AM
MadMac's Avatar
MadMac
Yeah a CVH reving to 8k is very high.
But with my XR3i my limiter is a bit odd in
1st 5.4k
2nd 5.6k
3rd 5.8k
4th 6.0k
5th 6.2k
nuts, but normally if I'm taking it easy it will be on about 3-4k I change gear.
Old Sep 26, 2004 | 03:05 AM
mattbibs's Avatar
mattbibs
when running about i always change before the dv sounds. in a FRST that means about 2.5k!!
Old Sep 26, 2004 | 06:27 AM
Gooey's Avatar
Gooey
my power band finishes at 6k so I try not to go above that, still good for 50 in first gear though
Old Sep 26, 2004 | 07:22 AM
sunny's Avatar
sunny
8500rpm
Old Sep 26, 2004 | 09:35 AM
Matt's Avatar
Matt
if we are talking generically then id say its quite pointless revving beyond peak power in most scenario's
i have soft cut at 7500, hard cut at 8 (whatever that means lol)
peak power was 7k on rollers but was only revved to 7k but given the turbo its about all over at 7k
shifting at 7k gives me a band of 3500rpm on boost
if you want to know what i think is high for a cossie and a cvh then 8500+ and 7500+ respectively, this obviously isnt in std form
Old Sep 26, 2004 | 09:44 AM
mattbibs's Avatar
mattbibs
your car felt really good at 7k revs matt!
felt even better when it was bouncing off the limiter in 2nd!!
Old Sep 26, 2004 | 09:50 AM
SassyRS's Avatar
SassyRS
Little Miss...
I dont really need to look at the rev counter, i know my car well so you just know when its time to change..
but i guess 7500rpm is a good cut off
Old Sep 26, 2004 | 10:41 AM
Hofajoab's Avatar
Hofajoab
i don't know what high revs are anymore
Old Sep 26, 2004 | 10:46 AM
Oranoco's Avatar
Oranoco
I never rev mine at all really. Normal use is reved to about 3k. If I'm razzing it I always try and change before the limiter but it picks up so quickly I tend to pop it off that limiter.
Old Sep 26, 2004 | 11:49 AM
MadMac's Avatar
MadMac
Yeah right steve, i have seen how u drive
Old Sep 26, 2004 | 05:48 PM
morpheus1967's Avatar
morpheus1967
Honda vtec revs to 8500-9500 as standard and has a 90k warranty.
My mex revs to 7k.
Old Sep 26, 2004 | 06:07 PM
Stu.H's Avatar
Stu.H
hows ur cacker mac?
Old Sep 26, 2004 | 06:14 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
RW
It made sense, it sounded sweeeeeeet
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
