** URGENT** Torque settings for long studs......
Jul 14, 2007 | 04:43 PM
As above torque settings for long studs on cosworth head ??
Thanks in advance
Jul 14, 2007 | 04:47 PM
stud into block or nut ontop of the stud to clamp the head down?
Jul 14, 2007 | 04:52 PM
Quote:
Nut ontop of the stud to clamp head down please
Jul 14, 2007 | 05:05 PM
Jul 14, 2007 | 05:09 PM
I got told they are torqued in the same sequence and stages and to the same torque as normal head bolts
Jul 14, 2007 | 05:16 PM
85-90 ftlb
Do all to 30 then all to 60 then do all to final.
Lee
Jul 14, 2007 | 05:18 PM
My SCS note says:
90 lbs/ft (all the inner ones) and 95 lbs/ft for the outer FOUR.
Quote:
Originally Posted by TiB
85-90 ftlb
Lee
Thankyou
Jul 14, 2007 | 06:36 PM
I finish mine at 120 lb ft.
Jul 14, 2007 | 06:40 PM
Quote:
That is what I have been told too
Jul 14, 2007 | 07:12 PM
matters on whats used on the threads.
Off Burtons website.
ARP Head stud and nuts, 95lbft with arp lube, 135lb/ft with 30w oil.
Jul 14, 2007 | 07:59 PM
I lube with oil, then torque up then retorque after 1 hour, and they always need it!!
Jul 14, 2007 | 08:04 PM
1 hour after 1st torque, or 1 hour after 1st run up?
Jul 14, 2007 | 08:12 PM
1 hour after FIRST TORQUE.
Jul 14, 2007 | 11:18 PM
Brave
Mine have always been fine at 90 so i wont be trying any tighter.
Jul 17, 2007 | 07:15 PM
So what about the studs into the block?
and whats needed on the tread, normal thread lock or oil?
Jul 17, 2007 | 11:18 PM
Long studs should be into the block at 50ftlb. and threadlocked.
Lee
Jul 17, 2007 | 11:35 PM
Quote:
Originally Posted by L8 ECU
My SCS note says:
ive never understood this
Escortdriver1
Nov 1, 2015 07:55 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
Toe Knee
Aug 23, 2015 08:31 AM
Billy_RS
Aug 3, 2015 08:43 PM
