removing rear halfshafts on 2wd??
Old Jul 13, 2007 | 05:23 PM
lammylama's Avatar
lammylama
Default removing rear halfshafts on 2wd??
I need to know how to remove the halfshafts from a rear diff on my 2wd saff.....never done a cossie before but ive only ever seen the snap rings like on fwd cars.....saffs obviously dont have this set up so how do i get them out.
Also whats the big ring with the notches on that you can see between the shaft and the diff casing????.....if you know what i mean
Old Jul 13, 2007 | 05:56 PM
The big ring is to adjust the preload on the bearing for the flange/shaft inside the casing itself.
They simply unbolt with 6 allen or torx bolts either end so dead easy.
Old Jul 14, 2007 | 07:05 AM
lammylama's Avatar
lammylama
thats what i thought.....my fookin neighbour decided to undo that ring and has broken a load of the notches off. so i need to replace the ring now but how tight do i do it or is it a specialist job to set it up??
i could kill him!!!!!!!!!!!!
Old Jul 14, 2007 | 07:13 AM
Bummer!!
Never done one but preload is crucial to long life, I have done preloads before on things with FISHING SCALES, and measured levers so ratio was same etc.
Just find out what preload should be and DIY, not hard just a bit of an arse to do under car.
I'll look into this for you but will take a few days.
I would not let your neighbour do any more(damage)!!
Old Jul 14, 2007 | 07:19 AM
lammylama's Avatar
lammylama
tell me about it....hes like a bull in a china shop,im really annoyed TBH.
diff is off the car if that helps and its a quaife atb too..all i wanted to do was take the shafts out to sell it as ive broken my car now.
i would really appreciate any guidelines on doing this right as i do not want to sell a quaife to someone knowing its not set up right.
Old Jul 14, 2007 | 07:46 AM
I don't know any thing for quaife!!
Old Jul 14, 2007 | 08:12 AM
lammylama's Avatar
lammylama
luckily i only live about 20 mins from quaife so i think im gonna drop it down there to get it adjusted......shouldnt cost a great deal to do hopefully but i need to get hold of the big ring 1st and the little bracket that holds it in place
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
