Oil temperature sender location
Jul 13, 2007 | 02:24 PM
Where is the best place to put an oil temp sender?
I was thinking of putting it in the sump, would that be OK, or more to the point would it give a good representation of oil temps there?
Ta
Spud
Jul 13, 2007 | 02:51 PM
That is where I have put some in the past.
It is only a representation of an average as it can never be correct all the time, it is cooler in the sump but hotter by the time it gets to the top etc as it has soaked up the heat.
Jul 13, 2007 | 02:52 PM
I've used an adaptor so that it goes in the drain plug hole.
Ideal
Jul 13, 2007 | 03:53 PM
mine is in my sump plug, works all ok
Jul 13, 2007 | 04:23 PM
Have seen most located in the sump either by welding a boss in or via the drain plug.
Steve.
Jul 13, 2007 | 05:12 PM
Where did you get the adaptor from? I got one from Real Steel yesterday for my autometer gauge and its completely the wrong one!!
Chris
Jul 13, 2007 | 05:20 PM
i want a sump one too. Where did ya get them from?
Jul 13, 2007 | 05:23 PM
i had mine in the sump
was an auto meter one
but ive bout a sandwich plate that goes invewteen the filter and it holds my oil press and oil temp senders for my gauges
i have that sandwich plate for my s1. Dont fit the cossie though i dont think.
Jul 13, 2007 | 05:24 PM
it does but you have to modify your existing thread as its too long for the new adaptor
need to chop off about 2 threads
Jul 13, 2007 | 05:26 PM
ahhh right. Thanks
Jul 13, 2007 | 06:05 PM
cheers guys
sump is coming off tomorrow so I was going to weld a boss in there
Spud
mjonathan24
Oct 29, 2015 10:39 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
hopper350
Sep 4, 2015 12:53 AM
