sapphire 4x4 rear calipers...
Old Jul 11, 2007 | 10:36 AM
magenta4x4's Avatar
magenta4x4
Default sapphire 4x4 rear calipers...
Hi all,
My sapphire rear calipers have seized AGAIN
I have come across a set of 3 door rear calipers but im not sure if they'll fit. Are the standard rear calipers the same for a 3 door, 2wd saff, 4wd saff and escort cossie?
Cheers!
Old Jul 11, 2007 | 11:12 AM
IANS2RST's Avatar
IANS2RST
4x4 sapphire calipers are a little wider than the 2wd versions to allow for a vented disc
time to get yours reconned
Old Jul 11, 2007 | 12:42 PM
magenta4x4's Avatar
magenta4x4
Im guessing that means more expensive?
Ive been told its not even worth going down the road of 2nd hand ones and a new set are about £100 each...
Old Jul 11, 2007 | 04:10 PM
You might as well just get some new calipers mate. The 4x4 calipers r wider as above cause of the vented discs.
Old Jul 11, 2007 | 07:28 PM
rosscoe's Avatar
rosscoe
Default calipers
£100 each????
thot they were a lot more expensive than that
Old Jul 12, 2007 | 02:49 PM
PSL's Avatar
PSL
Default Re: calipers
Originally Posted by rosscoe
£100 each????
Nah, I phoned Ford the other day for one £104 each in exchange for your old one. You have to leave a £15 deposit which is refunded once you bring them the old ones back!!
Old Jul 12, 2007 | 09:36 PM
Im sure u can get the cheaper from a local motor factors.
Old Jul 13, 2007 | 06:02 AM
Try BIGGRED.CO.UK, 01905 428793.
The last ones I purchased from a factors were £55 inc vat.
jason_nike
Aug 18, 2019 10:53 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
FlashRS
Sep 14, 2015 12:36 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Old ford
Jul 31, 2015 06:50 AM
