Some problems...
Old Jul 11, 2007 | 01:41 AM
GuGu's Avatar
GuGu
Default Some problems...
Hi,
I have a chipped Ecu and 13 psi boosted RST with frount mount cooler..But now I have some problems.
1- While the car is hot,on idling RPM falling down and oil lamp flashing for a second. Then the idle rpm begin to go between 500-900 . Why can it be?
2- The car goes to left side on accelerating then goes right after take my feet from throttle .. I set everything under the car.. Why?
3- When I buy 100 octane fuel, the car doesnt works good.. Why?
And questions not problems..
4- How much fuel do you spend for 100 kms?Please say it as litres..
5- What is the capacity of water tank?
Thanks for your answers..
Old Jul 11, 2007 | 02:55 PM
antony215's Avatar
antony215
Escort Rs Turbo
Default Re: Some problems...
Originally Posted by GuGu
Hi,
Oil light flashing is never a good thing sounds like you've got to thin an oil in there or your oil pumps on it's way out
Has it got an LSD box in it?? if not that can cause it to pull to one side or could be a bush or ball joint gone
Has you car been setup to run on that fuel??
LVC-Elvis
82
May 11, 2015 06:14 PM
Stu @ M Developments
279
Nov 11, 2012 05:29 AM
CharlieJ239
Jun 16, 2012 10:23 PM
ains
Nov 19, 2011 06:31 PM
