how can you tell if you got a genuine 2wd cossy diff
Originally Posted by tichy.cosworth
is there any way to now if you got a genuine 2wd cosworth diff
Jack the car up so both wheels are off the ground, and turn one. The other wheel should go in the same direction to prove the LSD is working. Also get someone to hold the other wheel still, and turn the other one, should be quite stiff to turn against the LSD
- If its out the car just do it on the output flanges
Nov 3, 2015 04:08 PM
