remove the ecu=electrical failures
Old Jul 10, 2007 | 04:05 PM
coswol's Avatar
coswol
Default remove the ecu=electrical failures
have one stage 1 chip and i come to retire it to put a standart chip (stage 0 Surpris ) but i have problems..... i disconnect the batery ground, i retire the ecu and the chip... but when i put the ecu again the car have electrical failures in the motor and let a injector open etc etc.....
what is the method to change the chip?
why i have electrical failures? maybe i need to disconnect and connect also the group a coil?
Old Jul 10, 2007 | 04:12 PM
abdr500's Avatar
abdr500
did you fit the chip the right way around
Old Jul 10, 2007 | 04:25 PM
coswol's Avatar
coswol
what ?
the chip have a position to mount it?
Old Jul 10, 2007 | 04:34 PM
Stu @ M Developments's Avatar
PassionFords Creator
You have plugged the chip in backwards pal, whatever you do dont do that with your new one!!
Old Jul 10, 2007 | 04:39 PM
coswol's Avatar
coswol
moder of main................ my mother !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 10, 2007 | 04:49 PM
It will have a SPOT or SEMI CIRCLE on one end normally to denote orientation.
Old Jul 10, 2007 | 05:13 PM
coswol's Avatar
coswol
very thanks
Old Jul 10, 2007 | 11:04 PM
Fixed? Or did you fry the chip?
Old Jul 11, 2007 | 01:15 AM
richm's Avatar
richm
the orientation notch is at the top of the chip in this picture
Kam B
Sep 24, 2015 10:40 AM
Tank Mike
Sep 14, 2015 03:56 PM
RSmark84
Sep 13, 2015 01:29 PM
little bram
Sep 10, 2015 10:45 PM
hopper350
Sep 4, 2015 12:53 AM
