Xbox 360 and HDTV for novice's...
Old Jul 9, 2007 | 02:36 PM
JamesH's Avatar
JamesH
Default Xbox 360 and HDTV for novice's...
please explain!
So you can get 1080p and 1080i... whats this mean exactly?
Whats the best "spec to aim for" and what is normal TV like with digi box too? I'd only want 32inch max
EDIT: I actually cannot spell
JamesH's Avatar
JamesH
And how much difference does it make with the Xbox compared to a "normal" TV
Old Jul 9, 2007 | 02:37 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Whats a Xbox 3360 ??
Old Jul 9, 2007 | 02:38 PM
JamesH's Avatar
JamesH
fuck off
Old Jul 9, 2007 | 02:39 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I might be wrong, but I don't think you can get true 1080p (Progressive) with a TV under 37"??
I don't understand it fully, but it's to do with the way the lines are made up on the screen. 1080p is the best resolution currently available and Progressive is better than Interlaced.
I'm sure someone else can explain more accurately!!
Adam_BlackRS
Ex Ford Man
Seriously tho.... Xbox 360's don't display ture HD as they don't run a HDMI interface.
Have a read on AV Forums, thats where i learnt alot and found my new HDTV
Old Jul 9, 2007 | 02:44 PM
Ryan's Avatar
Ryan
1080i is interlaced, which means the picture is made up of 2 scans, 1 consisting of the odd number of lines in the image (lines 1,3,5,7 etc) and the second made up of the even number of lines. (2,4,6,8 etc)
This creates a complete image but in 2 scans.
Progressive displays all the lines in the image at once.
1080P is the best resolution currently on the market
Old Jul 9, 2007 | 02:46 PM
JamesH's Avatar
JamesH
So can the Xbox360 run 1080p with the std (premium pack) normal/hd cables
Is there much difference between 1080i and 1080p?
And at what point do you need to get a HDMI cable for them, also how much are they wand where from, microsoft?
Old Jul 9, 2007 | 02:54 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the other way to explain it is that on some telly's the refresh only moves the pixels that have changed and doens't move the ones that haven't while on the better telly's all the pixels are refreshed every time
and no, the xbox360 can't run 1080p
and no you can't get a hdmi cable for them either
you have to use component cables
Carlsworth's Avatar
Carlsworth
Former Sponsor
i really dont know about the xbox, but on the ps3 the image is massively improved with hdmi lead
you dont notice though, unless you change back to normal lead
its amazing
cqrl
Old Jul 9, 2007 | 02:56 PM
aduz's Avatar
aduz
i hope your xbox lasts longer than mine...2 weeks and its fooked already
i hear sony calling
Old Jul 9, 2007 | 02:58 PM
JamesH's Avatar
JamesH
Cheers for that aduz Had mine since last december
So what is the most the xbox 360 can run through the component cables and is it worth doing
Old Jul 9, 2007 | 03:01 PM
Ryan's Avatar
Ryan
dont think the xbox can run in 1080, may be wrong.
Also as has been said i dont think they do 1080P in anything smaller than a 40¨
Plus u wont see the benefits at that small.
720P will look awesome on 32¨
Old Jul 9, 2007 | 03:09 PM
dojj's Avatar
dojj
i've got mine running on the 50" and it looks really good, with the component set up that is
if someone were to give me a ps3 to have and test with loads of games and stuff for free, i'd be quite happy to play that as well for a few hours a week and report on the difference
Old Jul 9, 2007 | 03:11 PM
JamesH's Avatar
JamesH
Well the TV will be in my room, hence 32" ideally
So at 32" what is the most the xbox will run at???
Old Jul 9, 2007 | 03:15 PM
Ryan's Avatar
Ryan
Dojj PS3 shames the xbox when it comes to the high end graphic stuff.
Resistance - Fall of Man on 1080P is truely stunning on 46¨
Old Jul 9, 2007 | 03:55 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Yep your right there and on 50 inch with 1930 and 1080p its fantastic
Steve.
Old Jul 9, 2007 | 04:04 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
Default Re: Xbox 360 and HDTV for novice's...
Can't comment on the X360 on an LCD as i've only ever played Dogsmoke's on my 32" CRT, which looks good enough to be honest, so must look fantastic in HD.
But watching standard broadcasts (freeview, normal sky etc) on an LCD is fucking horrible, they look really grainy and fuzzy, and both occasions i've seen it they have been on decent LCD's (panny viera 32", and a sony bravia)
I'd still have one though if i could justify paying for a new telly, when i already have a great CRT
Old Jul 9, 2007 | 04:09 PM
Ryan's Avatar
Ryan
as said there certainly not as good as a CRT on normal SD 428i signals, but then again, it does have to be seriously upscalled to fill the picture.
Old Jul 10, 2007 | 07:15 AM
JamesH's Avatar
JamesH
Anymore?
Old Jul 10, 2007 | 07:41 AM
JonnyBravo's Avatar
JonnyBravo
My xbox is running in 1080 mode through a Sony 1080 tv, as Ryan mentioned apparently they don't support that setting but it does change the tv settings when you alter them on the xbox.
The picture is incredible, noticably different from the 480 and 720 settings.
Old Jul 10, 2007 | 09:05 AM
Ryan's Avatar
Ryan
as said the increase from 480i to 720P is massive
and 1080P is even better but only noticed on larger screen on certain types of movies
Old Jul 10, 2007 | 12:32 PM
JonnyBravo's Avatar
JonnyBravo
Porn in 1080 looks amazing
Old Jul 10, 2007 | 12:34 PM
Ryan's Avatar
Ryan
Old Jul 10, 2007 | 01:07 PM
rsnissan's Avatar
rsnissan
Resistance - Fall of Man on 1080P is truely stunning on 46¨ :eek: :eek: :eek: :eek:
..............except for the fact its a 720p game :007: :cry:
Old Jul 10, 2007 | 01:27 PM
Ryan's Avatar
Ryan
i know they all are i think?
says on the back of the cover
Old Jul 10, 2007 | 03:48 PM
buzznwood's Avatar
buzznwood
Very few game will be rendering at a native 1920x1080, if they are then there not going to be doing much. If any game is going to render at 1080 on the ps3 then it will be doing 960x1080 this is to get around the fact that the ps3's internal scaler is a pile of rubbish that can't scale 720 to 1080i properly. On both consoles your better of just setting the output to 720p.
Dojj, as to the ps3 shaming the xbox when it comes to high end graphics just stick with your 360 unless you fancy a cheap blu ray player.
Old Jul 10, 2007 | 07:00 PM
dojj's Avatar
dojj
couldn't afford to buy a ps3
nor justify getting one as a blu ray player
or put another shelf up to stick it on
the wife would kill me in any case
Old Jul 10, 2007 | 09:11 PM
JamesH's Avatar
JamesH
Right I can get a 32" Panasonic HDTV that will do 1080i for £400?
Old Jul 10, 2007 | 10:11 PM
BigMouthBillyBass
I'll give you £350....Done!
Nov 1, 2015 06:53 PM
slowpoke
41
Oct 29, 2004 06:51 PM
21
Sep 4, 2004 09:27 PM
Wazzzer
Aug 3, 2004 06:20 PM
