RS500 - Buying advice??
Old Sep 24, 2004 | 09:43 PM
oscar wightman's Avatar
oscar wightman
Default RS500 - Buying advice??
What should i look for when viewing an RS500 - Just want to make sure that its genuine.... Obviously larger turbo/extra injectors and spoilers (but these could be transplanted....
Any help would be cool!!
Old Sep 24, 2004 | 10:08 PM
Karting's Avatar
Karting
There is a buyers guid on the RS500 out 1st October in Fast Ford which might help you. Chassis number (which is down by drivers seat & under bonnet) should be GBBE GG 38600 to 39099. Engine numbers should be YBD0015 to YBDO537, to be a genuine 500 also when ariel is up, press rear boot lock and the ariel will come down, wiring on the ariel is different than another Cosworth.
Old Sep 25, 2004 | 02:59 AM
RS500/364's Avatar
RS500/364
rear beam has two mounting pionts
battery tray has a corner cut out some other bits to
Old Sep 27, 2004 | 05:19 PM
oscar wightman
Cheers chaps
Old Sep 27, 2004 | 06:17 PM
Karting's Avatar
Karting
rs500 the bulkhead has been modified (reinforced).wiring loom increased to 65mm , hood heatshield. There is no comparison with a 3 door. I have listed some things that people do not know, but I could be on here all day. There is too many people who want to make a 3 door look like an RS500 which they will never be able to do.
Old Sep 28, 2004 | 09:46 PM
Karting's Avatar
Karting
Hope this information helps.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Marino
Sep 12, 2015 11:10 AM
dojj
Sep 8, 2015 08:31 AM
RSBryden
Sep 6, 2015 08:39 PM
