Spark plugs ??
The AGPR12PP8 are std 4x4 yb plugs not had much in the way of testing on over standard yb's not a dis Tab !
The 071C's are also a std motorcraft plug but tested and reliable @ 400hp plus with no side affects then the next step IMHO would be denso irridiums but for value reliability and stats speaking for them self 071C's all day long .
Regards Doug .
Regards Doug .
Regards Doug .
Regards Doug .
that i had were pretty much the best plugs available for stg1 applications.........
good enough reason to fit them for me!!!
Don't know about higher up the power levels though...
I did kinda realise that euan, what wi the 8 greens an that.....
Was just commenting on a reply from earlier.
Always good to know what plugs you big power blokes recommend,
'cause you never know when the info could come in handy!!
Get the info 1st hand!!!!!
Regards Doug .
Regards Doug .
Regards Doug .
Originally Posted by col cos1
bcr8es £2 a plug on mine
i fitted £60odd quid iridium hks things just for it to have a missfire on the rollers
the densos were good but always had a tiny miss at a certain point of the rev range that is now cured after fitting the BCR8es
I have used PP8`s and found them fine till 380 bhp, i now use champion QC57C race plugs (@ 450 bhp ) found them to be a bit poor when the engine is cold but fine when hot.. out lasted all the others for reliability..
i currently have pp8 in small turbo gapped to 0.7. Im going to be changing these to pp12 and gapping to 0.85 as it currently has a splutter and slight miss on the pp8. Hope this will cure the splutter up a bit as have rolling road day on 28th too
Thanks for all the info guys.
I should of been more clear at the start as to what i was after. Sorry bout that.
Anyway your info has helped loads. Thanks again
just get Alan to do the plugs when he maps it
deathrider666
Sep 28, 2015 06:12 PM
