Inlet Manifold gaskets...
Old Jul 8, 2007 | 04:35 PM
Rolls's Avatar
Rolls
Default Inlet Manifold gaskets...
AS title - what do you guys recommend? - looks like mine is leaking (which I hope may be a reason for the prob's i've been having - although I have re-gapped the phase sensor, and now it starts as it should )
Basically, if you spray carb cleaner over the inlet - head join on cylinder 4 the engine note changes a fair bit. I am correct in thinking inlet gasket aren't I?
Old Jul 8, 2007 | 04:39 PM
THE RADMAN's Avatar
THE RADMAN
sounds like it, i fitted cometic ones on mine when i did it , inc throttle body and plenum ones, havent had any probs with them
Old Jul 8, 2007 | 06:29 PM
Rolls's Avatar
Rolls
Ok - cheers
Where did you get the gaskets from chap? I'm guessing mr Rainbird may be a good bet?
Also, just how much of a pig of a job is this to do? - I have a horrid feeling that its going to be a complete arse of a job
Old Jul 8, 2007 | 07:22 PM
redrsmk5's Avatar
redrsmk5
Yes cometic are A1....Rolls its easy mate
Old Jul 8, 2007 | 09:56 PM
dave cos4x4's Avatar
dave cos4x4
just have to have small hands to get at them nuts.
cometic one.
Old Jul 8, 2007 | 10:22 PM
THE RADMAN's Avatar
THE RADMAN
think i got my gaskets from pj motorsport
Old Jul 9, 2007 | 02:19 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I do a lovely 1mm thick fibre gasket for £18 + delivery .
Old Jul 10, 2007 | 06:06 AM
COMETIC all the way, done all of mine with these and reusable all of them, including water pump one.
They do not creep or anything.
MATT LEWIS 01922 692424, top man ace service.
Old Jul 22, 2007 | 04:32 PM
Rolls's Avatar
Rolls
Ritey then guys, finally back after a week away mountian biking - how exactly do you get the inlet off? - it looks like its going to be mission impossible to get the bottom bolts off
Old Jul 23, 2007 | 06:40 PM
Rolls's Avatar
Rolls
anyone - pls? - is it a case of remove TB, then outer, and then inlet?
cheers
Old Jul 26, 2007 | 09:28 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
cheers
nope you can get the inlet manifold off without taking the cover off.
you can just about get your arm under the manifold to get the nuts off its not that difficult TBH.
Old Jul 26, 2007 | 10:47 PM
dave cos4x4
4-5 nuts on the top or 4-5 underneth......you need smal hand and a small spanner.
dizzy cp and rotor arm off,leads out of the way and you should get it.
do the bottom ones first.
Old Jul 27, 2007 | 01:00 AM
THE RADMAN's Avatar
THE RADMAN
prepare for some bruises
Old Jul 27, 2007 | 07:33 AM
Rolls's Avatar
Rolls
Nice - cheers guys - i'm brusied to fook from mountain biking in verbier anyhow, so that will make no difference lol! - i'll give it a go tomorrow in teh hope this is the cuase of my problems....
Old Jul 27, 2007 | 09:38 PM
dave cos4x4
should be ok mate.
Old Jul 27, 2007 | 09:42 PM
Dan@Rapid-Ford
why you trying to scare him Dave its not that bad just gotta have hands like jeremy beadle
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
