Mitsubishi Pajero
Next door neighbour has one, but theirs is a 92 model (i think they're the same shape as the 1990)
They have a fucking HUGE caravan (i'm talking twin axle, in excess of 25ft) and it manages to tow that alright
Originally Posted by AlexF
anything to look out for?
Alex
Alex
I use a f reg shogun 2.5 td for towing and general abuse its been the best tow vehicle ive had. Automatic gearboxs are expensive if they go! mines a manual and had noisy gearbox bearings but got that done for Ł300 been good for last 4 years
if you don't have it, i will
i could do with an off roader for a bit to have a play in the woods with my mate's range rover.
has it got a locking centre diff?
i could do with an off roader for a bit to have a play in the woods with my mate's range rover.has it got a locking centre diff?
erm its got selectable 2/4wd and 4wd low
Alex
I've got a 2.8 as a tow car.
Apart from the usual crap fuel consumption, it also suffers from a common problem.
The oil seal in the diesel pump unit very often goes, causing poor running, stalling etc.... Very well documented, and not too bad a job to do, as I've just done it.
I have a 2.8 LWB manual, only had it a couple of months, but I like it so far
Check out
http://www.pocuk.com/forums/index.php
and
http://www.pajerouk.co.uk/forums/index.php
for any info you might need
Check out
and
My sister has a LWB 2.8 Pajero and it pulled a Cossie on a bloody heavy trailer no bother. (Im sure the thing was cast iron
Diff is gone on it as only one of the rear wheels drives it but knock it into 4x4 and it was effortless. Thirsty buggers tho!
)Diff is gone on it as only one of the rear wheels drives it but knock it into 4x4 and it was effortless. Thirsty buggers tho!
wildheart
Jul 20, 2005 01:37 PM
jamieslittleracer
Jul 24, 2004 02:52 PM
