Wiring escos moretts
Hi all, Im having a bit difficulty wiring these things up.
Id of thought it was fairly straight forward but there is a couple bits thats confusing me
Where do the inner lights get wired to as i cant see where they go?
Also when i put side lights on, what lights should be on?? the outer ones? inner ones? or both?
Im sure there was a post about an idiots guide to wiring these up but couldn't find it in the search.
Any help greatly appreciated
Mine is kinda doing something like that just now.
The outers are dim on side lights, Then brighter on dip beam, then well bright on main beam.
At no point do the inners come on. Must be my dodgy wiring
Originally Posted by glancy2081
sounds as if the wiring for full beam is connected to the outer lights instead of the inner ones
GAZ345
Cheers for that bud
Originally Posted by Metpol
Bin em and get back to standard... thats what I will be doing.
Looks pretty awsome tho :
f---k sake!! how hard is it!!! 20 minute job----(if that)are you ready for a car or what!!
inner full beam-
outer-dipped and side light-thats it!!!! why would anyone think the outer is full beam!!!!!-job done m.o.t passed-(thats the sign you have done it right-or use a garage door/white wall to get light heights set up
small children can do it if the buggy is pushed up close to the bumper!!!
inner full beam-
It is a good looking cossie Escorton8.. I think the black wheels etc make the lights seem to work. I just prefer ones that look pretty standard to keep the standard lights.. I have the morettes on my one and just fancy a change.
inner full beam-
inner full beam-
Originally Posted by stookay
jam
are they the ones a swapped jas for his standard lights ?
regards stookay
regards stookay
.Jason think all the wires on your old ones are labeled up. Can you remember if they are??
jam to be honest i can remember , andy raeburn stripped them off and put new lights back on , think the multi plug fits onto the loom and it had a link wire to drivers side headlight
regards
stookay
regards
stookay
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Steve Escos
Oct 1, 2015 06:57 AM
