PassionFord Fantasy Footie 2007/2008
All setup for this season (and I will win it this time !)
If you played last season then you can use your old login
PassionFord league code is : 27-82
If you havent played before then follow the following instructions to join up !
To Join goto www.premierleague.com
Scroll down and select Fantasy Premier league (on left hand side)
Register !!! (or enter password if you played the last season)
BINGO !!!!!
Select your team !
Once your done goto LEAGUES (righthand menu)
Join a private league and enter the following league number :
27-82
THAT’S IT !!!!
Can a Mod sticky this for a bit
BINGO !!!!!
Select your team !
27-82
THAT’S IT !!!!
Im in again!!!!!!!!
Had a mare with itlast year,as i forgot i had a team till just fater xmas,and i was gettin my ass spanked in a true Shef utd styley!!!!!!!!!
But im ready,with a BELTING team this year!!!
Is it me or does it seem your money goes ALOT furter this year??
Pete..
Pete..
Originally Posted by pollocks
can you change your team at any time our are there transfer windows i really should have read the rules lol
im confident The Speshull Ones will take the title
Originally Posted by DanRSturbo
Transfer window opens in January, where you canchange a max of 3 players, not sure about losing points though
Read the rules on the Premier League Fantasy League !!!!
Transfers:
Basically you can make 1 transfer each week which, other than the values of the players will not cost you anything.
HOWEVER, you can make more than 1 transfer each week to the cost of 4 league points per extra transfer.
You also have 1 wildcard per season. this enables you to do as many transfer for that week as you want, if you wish you can change all 15 players and you not be docked any league points for it !
As I said before its worth 5 minutes going over the rules.
Oh one more thing, until the first deadline (11th Aug 11am) you can change your team as many times as you want ! So if you have started with a team and Tevez does goto Man U then you can make that transfer and it wont cost ANY league points as the league has not started yet !
Good Luck all !
(you'll need it
Transfers:
Good Luck all !
(you'll need it
Originally Posted by Tangodeltasierra3
So is there any way of copy n pasting yer squads then to compare, mines a right side im telling you hehe
Originally Posted by Franco
Can you sign up to more than one league? As i'm already doing this through work?
