Cossie 2wd and 4wd con rods, Whats the difference?
Old Jul 6, 2007 | 06:40 AM
Fiecos Dan's Avatar
Fiecos Dan
Default Cossie 2wd and 4wd con rods, Whats the difference?
i was on the under standing that 2wd and 4wd rod's are different,
But i stripped my Fiecos engine, and found some 2wd rod's i've had sitting around for years, and the part number on the side are the same.
The only difference is above the grudgen pin (sp) on the 4wd rod's there's alot more metal? So Wieght/balance.
Can anyone clear this up?
The number on the sides of all the rod's are 'X YN00002'
Cheers Danny.
Old Jul 6, 2007 | 08:33 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
What weight is etched into the bottom?
4wd ones seem to be more likely to be an "H" from what ive seen, but Im not convinced there is a hard and fast rule.
Old Jul 6, 2007 | 08:39 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
all the rods are the same on either 2wd or 4x4 as are the cranks,no difference what so ever,
Old Jul 6, 2007 | 08:41 AM
radiant red's Avatar
radiant red
something to do with offset dimensions to lower piston slap??
Old Jul 6, 2007 | 08:47 AM
Micky The Finn
Former Sponsor
on the pistons not the rods,why do folk try so hard to distort the facts on this site by posting stuff they dont know about?
Old Jul 6, 2007 | 08:48 AM
Chip's Avatar
Chip
Thats the pistons not the rods though surely?
Old Jul 6, 2007 | 08:57 AM
Chip's Avatar
Chip
He wasnt trying to distort facts, he was trying to help.
And now that me and you have both corrected him, it makes this thread useful, thats the GREAT thing about this site, if crap does get posted, it normally gets quickly corrected which helps dispell the myths
Old Jul 6, 2007 | 09:09 AM
Disabled Account's Avatar
Disabled Account
Just to confirm, on the Cosworth Racing website they list ONE type of YB rod only:
Catalogue » Heritage » YB Con Rod Assy » CON ROD (YB0023)
Product
CON ROD (YB0023) £150.00
http://www.cosworth.com/shop_item.php?productid=138
radiant red
now i think about it obviously i am wrong. be silly to design a bent rod. still would like to know how the piston design is different.
Old Jul 6, 2007 | 09:15 AM
CozzyBrom's Avatar
CozzyBrom
there is one rod type as doug says but there are also matched sets ie heavy and light ones if you have unmatched set get them end to end balanced
Old Jul 6, 2007 | 05:22 PM
Fiecos Dan's Avatar
Fiecos Dan
Thats the only difference i could see, was the wieght.
Old Jul 6, 2007 | 07:15 PM
Stu @ M Developments's Avatar
PassionFords Creator
And standard of course.
Old Jul 6, 2007 | 07:19 PM
Fiecos Dan's Avatar
Fiecos Dan
Just checked the rods.
They all have H engraved on the top and the cap.
The top of the rod meterial differ'd from
9.3mm = 4wd,
5.9mm - 7.75mm = 2wd rods.
Also wiegh'd them,
Caps wiegh 158 - 167 grams, Rods = 463 - 474 grams, both together in they sets 629 - 633 grams.
But one of the 2wd rod is the same wieght as my Fiecos 4wd rod, for the cap, rod and complete set.
Old Jul 6, 2007 | 07:31 PM
Jim Green's Avatar
Jim Green
Thats assuming someone hasn't had the engine apart before you, and put an un matched set it......
Old Jul 6, 2007 | 07:35 PM
Fiecos Dan's Avatar
Fiecos Dan
The 4wd rods are all the same.
But the 2wd rod's come out of a rebuilt engine that a mate rebuilt. Which did have a new rod fitted on No 4, but looks like it had a another rod before that, as had 3 different style of part number stamp marks.
Old Jul 6, 2007 | 07:54 PM
Jim Green's Avatar
Jim Green
That could be the difference ....... a couple of rods from a "heavy" set, and some from a "lighter" set.....Basically four rods, from the same engine would normally appear identical to each other.
Old Jul 6, 2007 | 08:27 PM
Fiecos Dan's Avatar
Fiecos Dan
So, Have the lighter set got 'L' engraved? or any other I.D marks?
Old Jul 6, 2007 | 09:38 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Rods other than weight .... yes, Cranks... no!
Old Jul 6, 2007 | 09:41 PM
mechanic28's Avatar
mechanic28
interesting thread this!!
Old Jul 31, 2007 | 06:54 PM
Fiecos Dan's Avatar
Fiecos Dan
edited.
Old Jul 31, 2007 | 07:16 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
the cranks are different-
the nose of the crank that the crank pully goes onto is slighly tapered on the 4x4
Old Aug 5, 2007 | 10:49 AM
Fiecos Dan's Avatar
Fiecos Dan
Cheers,
i noticed that a month a go, when i try fitted my escos front pulley on a 2wd crank.
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Gadget
Aug 26, 2015 01:02 AM
RsS2daz
Aug 14, 2015 05:26 AM
lockie
Jul 31, 2015 10:03 PM
