Saph cossie 4x4 exhaust tail pipe
Old Jul 5, 2007 | 05:22 PM
Default Saph cossie 4x4 exhaust tail pipe
Will i have 2 cut my back bumper so that a 4inch scorpion tail pipe exhaust will fit or will the bumper b ok.
Old Jul 5, 2007 | 05:29 PM
My 4" scorp fits ok on my 2wd if that's any help, plenty of room, but need a heat shield bit to stop paint burn!!.
Old Jul 6, 2007 | 06:43 AM
Sweet thanks i was talkin 2 someone n they said that u have 2 cut the bumber 2 get it 2 fit.
Old Jul 6, 2007 | 11:07 AM
xr_triplow_turbo's Avatar
xr_triplow_turbo
my cossie has a 4 inch its fine, but it is tight, use polybush exhaust rubbers just to stop it melting the plastic when u go round a corner sideways.
Old Jul 6, 2007 | 12:33 PM
Ridgey's Avatar
Ridgey
If you do put on poly exh rubber just do it on the end hanger by the tail pipe only.
The rest of the exhaust especially nearer the engine needs give to move, otherwise things break under strain.
DixieTheKid
Jul 23, 2023 10:16 AM
andy130
Oct 2, 2015 08:48 PM
CossieRich
30
Sep 8, 2015 10:08 PM
jaysoc1
Aug 21, 2015 05:38 PM
