Sierra - Granada Diff Ratios ?
Has anyone got a link to any sites that lists the diff ratios fitted to the Sierra and Granada's?
Also what models/ yr has the most saught after ratio?
ta
ta
Originally Posted by JonnyBravo
Is it a 3.9.1 your after ?
They came from a 2l granada iirc.
spent ages searching for one recently and did eventually source one but they are very rare it seems.
you need to find out withy ou ant a 7 inch or a 7.5 inch diff to fit to wehre you want to fit it too though, and the granada has differentbolt fixings to the seirra but nothing that can't be solved
i've got a 3.14:1 dif in mine but they also did a 3.36:1 as well as the 3.38:1 and a 3.62:1 and a 3.64:1 so you need to look for auto V6 granada's if you want the lower ratios
Siera owners club site has a list of all models with what diff, ID pictures and the codes to read the tag / chassis plate
3.14 is sought after by the bike engined kit car builders.
