Look who's bidding on this item.......(now with link)
http://cgi.ebay.co.uk/cosworth-rally...QQcmdZViewItem
ATM
Guess that will get bolted to an old standard YB lump and be sold as a Mountune WRC genuine complete engine...............
ATM
And then, as polly says will be bolted to a smokey fucked old 2wd engine on a .75 crank and 1.0mm oversize bores with the head on it's millionth skim, a leaky std head gasket and ropey 200,000 mile followers and cams and pistons. It will then be advertized as a full WRC spec engine with a full rebuild for £9000, with £2500 postage and packing cost, and then when some poor fucker actually buys it, they will be sent threatening E-mails and abused for daring to complain about the shoddy parts
You will then also get a reply calling you a "fucking wanker"
, and saying they used to work for boreham so know everything EVER, and you are obviously a passionford muppet
Yup, ATM (arse to mouth) ,Stay well away from them, Eddypain2001 is ATM's ebay name, makes it a bit easier for them to scam poor fuckers who have heard about ATM's god-awful reputation, but not Eddypains2001 user name
If you ever get offered anything by ATM, go to a local scrapper, look for the worst fire damaged smashed car you can find, and pick the most fucked part you can find.... It will be in better condition than somthing ATM describe as MINT
Originally Posted by RWD_cossie_wil
.......................You will then also get a reply calling you a "fucking wanker"
, and saying they used to work for boreham so know everything EVER, and you are obviously a passionford muppet..................
just for info,mountune didnt and dont use three door baynet style oil cap rocker covers,this one was on a suposed mountune engine a friend baught but he baught it off a well know hood from the york area so we took it with a pinch of salt,just as well really.
paceo
Sep 25, 2015 08:05 PM
