How to increase your final drive ratio??
Old Jul 3, 2007 | 11:56 PM
Liams's Avatar
Liams
Default How to increase your final drive ratio??
As above! Can someone shed some light on whats needed to make a s2 box long ratio?
About to have my box rebuilt so thought id do it! Am I right in saying a different crown and pinion is needed?
Any help appreciated
liam
Old Jul 4, 2007 | 06:43 AM
Badman38's Avatar
Badman38
Default Re: How to increase your final drive ratio??
liam
correct i am having mine changed at the moment
Old Jul 4, 2007 | 08:35 AM
Liams's Avatar
Liams
Whats the crown and pinion from?
crazycage's Avatar
crazycage
liam
what power are you running and whats your rev limit and tyre size?
Old Jul 4, 2007 | 09:20 AM
105epwr's Avatar
105epwr
thing is tho if u r making it taller gearing your 0-60 or 0-100 will go down i think s2 gearing is good unlike s1 think maybe diesel gears r longer
Old Jul 4, 2007 | 09:33 AM
crazycage's Avatar
crazycage
on a s2 gearbox @6500 rev limit you can do 1st38 2nd62 3rd92 4th124 5th155 or @7000 1st40 2nd67 3rd99 4th134 5th167 . thats on 205/40/17 tyres
Old Jul 4, 2007 | 11:21 AM
Liams's Avatar
Liams
300hp on the rev count think it goes just under 7k, how accurate the old gages are I dont know should be 7k! On my road angel ive seen 146!! Would the quaife diff make any difference to this?
Old Jul 4, 2007 | 11:23 AM
Liams's Avatar
Liams
Oh and im only running 15's
Old Jul 4, 2007 | 01:57 PM
JimmyBoy's Avatar
JimmyBoy
At a guess, with 15's I would take about 5mph off each speed quoted above.
Old Jul 4, 2007 | 02:18 PM
Badman38's Avatar
Badman38
either 3.58 escort diesel or 3.33 fiesta mk2 diesel the 3.33 might be too long lol longer gearing would suit my engine more then a 3.82 would.
i'm changing the spec a bit less boost but more nitrous i wont have a problem pulling the speed, fifth gear might cause me a problem.. but i will have to wait and see
Old Jul 4, 2007 | 03:31 PM
Liams's Avatar
Liams
Cool cheers for the info sean With the amount of power your running how can 5th possibly be a problem lol
My car just feels like it runs out of gears it pulls so well, it goes through 5th like most rs turbos do in 3rd If its a problem il be hopefully increasing the power soon so should level itself out!!
Old Jul 4, 2007 | 03:38 PM
Rick's Avatar
Rick
normnal escort 1.6 is 3.55
Old Jul 4, 2007 | 05:45 PM
Fiecos Dan's Avatar
Fiecos Dan
early xr2's run 3.58, as this is what i replaced my s2 box nearly a year ago.
i upped it, as with the RST s2 box, i was always hitting redline in top, half way thro a race, as well as on track days, 2nd was to high, but 3rd was to low, so lossing alot comin out of bends.
it helps in 1st, 2nd and 3rd, but does slow it up quite abit in 4th and 5th, but i dont max out straight away no more.
Old Jul 4, 2007 | 09:12 PM
Liams's Avatar
Liams
Fiecos Dan, Cheers fella thats my exact problem get to have a play with a cozy and before you know it your flat out
So whats the ratio of a standard s2 box then? If the escort diesel is 3.58 and fiesta diesel is 3.33 woulded the normal escort of 3.55 be a in the middle? Or does it not work like that
Dont know anything about gearboxes so bear with me
cheers
liam
Old Jul 4, 2007 | 09:16 PM
Fiecos Dan's Avatar
Fiecos Dan
a RST s2 is a 3.82 final.
ps, my runs 195/45/15's,
On my old s2 std rst gearbox when at brunters i done @ 6200rpm(rev limit) i did 2x 133mph by half way @ brunters @ the PF fiesta thrash my snoopper read 135mph, and the racelogic read 133.3 mph.
but on same gearbox, with a different spec head/cam, i have done 140 on my snooper up hill, and on flat, @ 6500 rpm, and passengers.
And with the new box, @ 5900 rpm my snooper reads 143mph
Old Jul 4, 2007 | 09:47 PM
Liams's Avatar
Liams
Same size tyres as mine!! Ive seen 146 on road angel at 7k, I think my rev limit is 7k anyway!
And you run a 3.58!! You worked out what the speed would be at 7k? Suppose around 160 odd?
Old Jul 4, 2007 | 10:13 PM
Fiecos Dan's Avatar
Fiecos Dan
Roughly
with 3.58 = around 167mph @ 7000rpm, 3.82 @ 7000rpm = 150mph.
Old Jul 4, 2007 | 10:29 PM
Liams's Avatar
Liams
Cool, think il try give this a go! Did you get the bits out of an old box or worth buying new? If you can still but new that is?
cheers for the help
liam
Old Jul 4, 2007 | 10:35 PM
Rick's Avatar
Rick
3.82 7000 on 195/50/15s is 163!
Old Jul 4, 2007 | 10:37 PM
Fiecos Dan's Avatar
Fiecos Dan
i rebuilt a early xr2 box,
with new bearings, gaskets, seals and a ATB diff.
Old Jul 4, 2007 | 10:39 PM
Liams's Avatar
Liams
Would a quaife diff alter that at all, lowering it? Because I know I have 45s not 50s but im 20mph short of that? You saying that a standard rs box with a 7k limit your hitting 163
Old Jul 4, 2007 | 10:41 PM
Fiecos Dan's Avatar
Fiecos Dan
A diff doesn't do anything to the speeds.
Old Jul 5, 2007 | 12:15 AM
Rick's Avatar
Rick
195/45/15 - std s2 box at 7k is 157. 6600 is 148.
You're probably not revving as much as u think - std rev counter is hardly the pinnacle of accuracy.
Old Jul 5, 2007 | 01:53 PM
Liams's Avatar
Liams
Maybe im not
Cheers for the help guys!!
Old Jul 8, 2007 | 11:53 AM
Fiecos Dan's Avatar
Fiecos Dan
Originally Posted by Fiecos Dan
Roughly
just looked thro my notes, and above guess were incorrect,
0n 195/45/15's
3.58 @ 7k = 167.6 mph
3.82 @ 7k = 157 mph
Old Jul 8, 2007 | 04:02 PM
Rick's Avatar
Rick
Old Jul 9, 2007 | 06:22 PM
steven botes's Avatar
steven botes
agreed - my gotech reads lower rpm than my rev counter , probably as much as 100 rpm
IainRS1700T
Sep 25, 2015 06:44 AM
Bransby
Sep 21, 2015 05:29 PM
pabloXR
Sep 21, 2015 12:42 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
Adam Graham
Sep 6, 2015 06:04 AM
