sorry for posting in hear as it is not 100% cosworth but may help my cause,
didnt really get a replie to my last post dunno if its coz im a newbie basically got a mk5 xr3i full cosworth replica, running a cvh rs turbo engine was wondering as my wiring is a right mess from previous owner if a standard rs turbo loom can be used, aslo duz anydony know of anyone local to lincolnshire that can do this or will anyone be willing to do this for me if i pay them, i alos have a few dash wiring problems to, if you could get bnack to me i would be very greatfull coz at the moment im stuck with the car not running thanks alot
yeah as it is rs turbo engine and cossie shell etc wasnt sure so i posted in both, my mate has had a look seems to think it may be a escort engine but running fiesta turbo efi etc so if that helps let me know im not clued up on my fords cheers
The two most common Fiesta turbo ecu's are OFAB and OFAC, if can get the loom to match your ecu (they are slightly different) then it should be fairly simply to fit this to your car.
ok thanks mate il take a look, think i might just chop out the damaged wires etc and replace them myself got sum really good cable that is used from work heat and flame resistant
