4wd oil feed pipe (turbo)
would this be ok to use for a 4wd oil feed pipe
as ive just ordered a new turbo today and would like to get rid of teh original pipe as it looks a bit coked up
carnt seem to find anywhere that sells them bar here
http://cgi.ebay.co.uk/Cosworth-uprat...QQcmdZViewItem
so could i use this
so could i use this
i know but there around £50 or a little pipe
i may take it down to a hydraulic place and see if they can make me one
butjust thought that one on ebay may be worth having but a bit curious because its a bigger diameter pipe
Pipes with swaged ends are always cheaper than those with compression type fittings. Personally, I can't see why you would need a larger diameter oil-feed. Alot of ball-bearing applications can actually stand alot less oil-flow to the turbo.
isnt the standed one a swaged end like the one in the ebay link?
if so then this will do me fine lol
but im concerned that because its beigger it may rovided to much oil flow as ive heard this isnt good for a turbo
dont want to go through the hassle of going the 2wd set up means i have to remove so much crap to fit the t piece and line
would just like a new 4wd hose that sdoesnt cost the earth
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
muz
Aug 16, 2015 12:57 PM
