holding back????
right then i got myself a new s2 rst after 7months or so of not owning a rs sinse the escos, supposed to have a stage 2 hybrid t3, cam unknown spec, chip unknown spec k&n full stainless, its boosting at 17 and holding 15psi but the car feels like its holding back even in the wet give it a load of right foot in first and ull be lucky is it will spin the wheels? my last rst was running 7psi n ud have a job 2 stop that spinning in the wet!
has any 1 come across this problem before?
could my turbo be shot even tho its boosting ok?
or should i just get it set up and go from there?
cheers james.
cheers james.
had a quick play with the timing today and its ten times better and going like it should now
still going to get it set up by a tuner then i know its right but just glad it wasnt somthing major,
its a new clutch and now its running better shes slipping in 3rd in the dry now
