Cossie breather pipes query
My cossie is now back looking like a cossie under the bonnet but we have a query about where the breather pipes go. The top 2 are ok but its the 2 from the bottom we arent sure about. The one on n/s just vents below the car.
Question is where does the o/s one go to? Is it supposed to return to the block?
This is what my mate said "The hose connection looks like ¼” NPT, but the block seems to be ½” NPT"
Now i dont even know what NPT is lol!
So should the breather go back to the block? Does a lot come through there or would we be ok to rig up a small catch tank???
finally got it to work, (tis a work network prob not PF),
heres the link hope it helps
https://passionford.com/forum/viewto...895&highlight=
Originally Posted by NUTTIN RILLA
Did you not have a bolt with a connection for a hose welded on to it?
Chop...do not use that hole as a return as it is postively pressurised when the engine is running and oil will NOT drain agains the presure.
Use the hole under the ex manifold as a breather and reutn oil into a catch tank back into sump UNDER oil level
see GGR site for the best breather pics
phone me if you need
i'll try find the ggr site...
Take the pipe off the breather seperator when the engine is idleing and feel the pressure in it...its not much BUT it is there...imagine this at 6k revs...
Oil will not drain down the pipe.
mines never spewed anything out of the filters and as thats the only return it has i know it drains back to sump
Its only a trickle at most !!
I just couldn't see where on earth I was supposed to connect to under the exhaust manifold.
So, luckily Chop took the whole old engine to me and I nabbed the adapter and fit the drain onto the block, as per my Block picture above.
It was because I didn't want oil dropping back under the rear tyres......!!
Is it supposed to fit to some sort of adapter that fits on the sump drain plug? That seems to be the only sensible place to put it, as it's under the oil level and the sump can be drained through the adapter instead of taking off the swirl pot connection also.
Rob has got here first but as he says its back into the hole shown above.
Euan
where on earth do you mean mate?! we have no idea! we have the old block sitting there to look at too
Euan
Originally Posted by Lambchop
Euan
I was thinking that my self, where else is there?
