2wd front calipers
Old Jul 2, 2007 | 07:08 PM
hog's Avatar
hog
Default 2wd front calipers
hi
im fitting 2wd 4pot calipers to my kitcar and need to know which end the bleed nipples should be at top or bottom ?? as i dont know what side is which ,and which nipple should be last to be bled out of the two on each side ?
cheers ant
Old Jul 2, 2007 | 07:27 PM
Air rises so bleed nipples at TOP.
I always do nipple inner most first.
DAN P's Avatar
DAN P
should be up top m8 and some people say in side first
Old Jul 5, 2007 | 05:23 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the inside is the one with the brake pipe going into it
FlashRS
Sep 14, 2015 12:36 PM
FlashRS
13
Aug 31, 2015 06:02 PM
C2 MAK
Aug 20, 2015 09:46 PM
2wdsaph ben
Aug 17, 2015 03:17 PM
track.focus'd
Aug 12, 2015 05:53 PM
