Spun Shells - Tell tale signs
Old Jul 1, 2007 | 06:17 PM
haz87's Avatar
haz87
Default Spun Shells - Tell tale signs
Ive got a loud tapping..well knocking noise but it only does it under load or if quickly rev'd. If i hold constant speed it doesnt do it.
Sound like a spun shell
Old Jul 1, 2007 | 06:47 PM
pee vee's Avatar
pee vee
if its a CVH then its probably the cam?
spun shell you may well of seen a rod by now lol
Old Jul 1, 2007 | 07:00 PM
haz87's Avatar
haz87
Been driving around for 2 weeks with it now.. and i havent exactly driven sensibly either,lol. Took the whole hopefully it will shut up mindset
Old Jul 1, 2007 | 07:27 PM
dojj's Avatar
dojj
Resident Wrestling Legend
spinning a shell will drop your oil pressure and basicly fuck the bottom end if it's left for long enough
i span a shell on a fresh engine and, even after i stopped straight away when the pressure dropped and the engine starting knocking it still needed a cleaning up of the crank
spa pressure gauge warning light came on and i lifted off and stopped within a few seconds in case you were wondering
Old Jul 1, 2007 | 08:00 PM
discodenkelly's Avatar
discodenkelly
bounce, bounce, bounce
its a nasty noise that shouldn't be there so its best to strip the lump and get it sorted. I've had a shell go when I had me cossie and it was the kind of noise you describe.
bobsworth
77
Mar 24, 2016 09:30 PM
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
