Breather pipe
I've just noticed beside my oil filter I have a breather pipe that leads to just under the car with a little breather filter on the end.
Where is it ment to be conected?
Jase the pipe looks like it should be connected somewhere around the starter motor area, but I can't find anywhere to connect it.
It's just a normal hose around an inch wide with a plastic tube on the end thats obviously fitted somewhere
The pipe then goes just under the floor with a little k&n breather on it.
I asked the same question many moons ago Gary, but got a lot of confused looks!
Mine pointed downwards as in the second pic, never had a filter on the end either. If i remember correctly you can remove the downward facing part...
Sneaky suspicion that it once actually connected to the airbox in a former life
Get a bailey breather on it, then you can bin it all!
