torque settings needed asap PLEASE ?
Turbo-Nutters.co.uk
This is a Sapphire cosworth
I need the torque settings for the studs that hold the camshafts in please ? (Think they are the rockers they hold in place!)
Basicly the studs rounded out of the head so have it heli coiled but need to know what the settings are to put new studs in and the nuts please ?
If anyone has a pic of the haynes manual that owuld be great ?
Also whats the rocker cover settings does anyone know pelase to ?
Thank you!
cossie-nutter
Thank you!
cossie-nutter
The ACTUAL STUDS are set to 3.5-4.5NM for both M6/8, with Loctite648.
The NUTS that go to hold the CAPS on are tightened to 8-10NM for M6, and 19-23NM for M8.
The cover (r/c) is torqued to 10-15NM.
There is NO rocker, as nothing rocks!!, the cam caps bear directly on the cam, and this is what is being tightened down.
There is NO HAYNES manual for this car/engine.
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
