Removing front bumper.
From underneath there are 4 bolts on the crossmember to be removed (Well 2 removed and 2 slackened..) and then at each corner there is a black plastic clip which you need to turn 180 degrees(ish). The bumper should be free all you'll need to do is pull/ push it forward. The washer bottle will still be connected so you wont have that much flex untill it's disconnected.
You can also remove the small bolts under the front of the bumper, to the left and right hand side of the number plate, underneath will be 2 holes and these are used to adjust the height of the bumper, it can be done this way but I'd suggest you don't as those bolts are almost impossible to get back in
Once you get underneath it should be quite clear the bolts that need removed, they look tricky to get to but it's easy enough. Oh, and be carefull when twisting the plastic clips as they're easy to snap, very very easy..
Originally Posted by Aaroncast
GET ON YOUR BACK AND LOOK!!!!!!!!!!!!!!!!---------- WHO HELPED TO DRESS YOU THIS MORNING ??-LOL-EVEN A BASIC TASK CAN BE DIFFICULT TO ACCOMPLISH
I'm too old (33) for crawling around on the ground Lol.I'm use to following the Haynes manual for other cars that I had that told you to remove 20 things when there was a short cut that meant you only need to do half that. Always better to ask to see if there's any short cuts.
track.focus'd
Aug 12, 2015 05:53 PM
