Coilovers: harsh for road use? Can you adjust them?
Old Jun 30, 2007 | 08:05 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Default Coilovers: harsh for road use? Can you adjust them?
Thinking about fitting coilovers as an easy way out of my tyre/spring platform clearance issues.
Has Konis fitted at present, which I think are about right - can coilovers be easily adjusted like Konis?
Are different brands more/less suitable for road use?
Old Jun 30, 2007 | 09:48 AM
AndyPen's Avatar
AndyPen
My AVO set are adjustable for height and stiffness - I can only say that I don't have a prob and the handling is so much better.
Old Jun 30, 2007 | 11:37 AM
TurboShed's Avatar
TurboShed
Cossiemodo
That's it, I'm sold.
Old Jun 30, 2007 | 01:16 PM
mumbo jumbo's Avatar
mumbo jumbo
i had konis on the front and coilovers on rear fantastic results
Old Jun 30, 2007 | 02:07 PM
cossie604's Avatar
cossie604
^^^ lol I must have had the other half to your set up fitted to my 3dr before I went AVO all round then.....had Bilstein coilovers on the front and Konis on the rear (it was originaly Billies on the rear also but they were rose jointed and a tad too harsh for our shite roads in derbyshire ).
Old Jun 30, 2007 | 04:59 PM
TurboShed's Avatar
TurboShed
Cossiemodo
So maybe I could save £££ by keeping my Konis at the rear... Hmm... cos dammit coilovers ain't cheap, new sets on eBay are £500
Old Jun 30, 2007 | 05:01 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Old Jul 2, 2007 | 07:28 AM
foreigneRS's Avatar
foreigneRS
Testing the future
what's too harsh, the springing or the damping?
damping is usually adjustable in some way, although not necessarily in both bump and rebound, and not necessarily by much
springs are only £15 each and can be changed easily
Old Jul 2, 2007 | 11:57 AM
mumbo jumbo
i would fit the coilovers buddy much better than konis but depends what ur gonna use it for, the only reason iwent for coilovers on the rear is to stop it squatting on forward thrust lol
Old Jul 3, 2007 | 07:42 PM
Daveesaunders's Avatar
Daveesaunders
Got a set of AVOs on mine and the ride is fine I even have poly bushes all round
Old Jul 4, 2007 | 06:36 AM
I got AVO coilovers and poly all round it is bloody hard but good.
Fronts are adjustable for REBOUND.
Rear are adjuatable for BUMP and REBOUND.
Old Jul 4, 2007 | 11:30 AM
Ridgey's Avatar
Ridgey
I've found the GAZ coilovers £480 good, not too harsh for the road (on the softest setting).
But as mentioned above softer springs are cheap and readily available in a multitude of strengths from places like Rally Design.
Dave
Old Jul 4, 2007 | 11:46 AM
If you purchase AVO coilovers and don't like the spring rates they will exchange them ONCE for FREE.
Old Jul 5, 2007 | 07:35 AM
K.Goa's Avatar
K.Goa
Was out in a Gaz coilovered sapph yesterday, nice and firm, but not harsh, very nice!!
Old Jul 5, 2007 | 07:56 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Originally Posted by mumbo jumbo
...reason iwent for coilovers on the rear is to stop it squatting on forward thrust lol
What's wrong with squatting at the rear??
Old Jul 5, 2007 | 08:51 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you lose contact patch as the camber increases along with the toe
Old Jul 5, 2007 | 01:21 PM
mumbo jumbo
depends on who lol
Old Jul 5, 2007 | 01:22 PM
mumbo jumbo
mine was fully poly bushed too allround
Old Jul 5, 2007 | 03:13 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Does this still apply as much for 4x4 Cossie?
Old Jul 5, 2007 | 04:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yes and no.
yes in that the rear suspension design is similar and no in that 4x4 does not need to put as much power through the rear wheels anyway
not sure if a 4x4 squats at the rear on launching as much as 2wd, i've never had one
Old Jul 5, 2007 | 06:32 PM
TurboShed's Avatar
TurboShed
Cossiemodo
4x4s deffo do squat, but as much as 2WD I wouldn't know.
Old Jul 10, 2007 | 01:31 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Well, I just bought a pair of Avo Coilovers - fronts only. So, will see how it drives with them on front and the Koni's on the rear.
gambo08
Feb 4, 2016 10:49 PM
mk22door
23
Oct 2, 2015 10:06 PM
Fezman1
Oct 2, 2015 01:22 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
AJC
Oct 1, 2015 06:47 PM
