camber
Old Jun 29, 2007 | 05:55 PM
krisberic's Avatar
krisberic
Default camber
Is there anything to stop the rear tyres wearing on the inside, its a 2wd sapph and its lowerd on avo's
Old Jun 29, 2007 | 08:33 PM
iansoutham's Avatar
iansoutham
OCD Victim
Best thing is to de-camber the rear end. There are various methods, from shim-plates which are basically steel plates you put inbetween the rear hub carrier and the rear beam. These plates are angled to adjust the camber accordingly. You will have to get a machine-shop to make them for you.
Or you can simply shim it yourself using anything from a washer upwards (please note that I am not condoning this method due to possibilities of stress fractures occuring due to loading, etc..., but I have seen it done in the past.)
Old Jun 29, 2007 | 08:46 PM
MIKE R sells some ready made shims for this Ł10, they fit under the rear two bolts to angle bearing carrier slightly, but seem to do the trick.
Old Jun 29, 2007 | 08:53 PM
ellicoss's Avatar
ellicoss
Yes have these on my saff do the job well
Old Jun 30, 2007 | 12:17 PM
krisberic's Avatar
krisberic
Default camber
Mite sound daft but how can i get hold of Mike R. Could do wi some, is it a shop or just some one who makes em.
Old Jun 30, 2007 | 12:55 PM
cossiegreg1's Avatar
cossiegreg1
MIKE RAINBIRD He is regular on here. his shop is R + B Motorsport.
Old Jun 30, 2007 | 12:56 PM
cossiegreg1
www.randbmotorsport.co.uk
Old Jun 30, 2007 | 02:54 PM
krisberic's Avatar
krisberic
Default camber
Thanks alot.
Marc sierra
12
Aug 30, 2015 10:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
xrsi
Nov 14, 2005 10:48 PM
DaveEscos
Oct 29, 2005 12:42 AM
Dan@Rapid-Ford
Jul 16, 2004 03:22 PM
