just changed my....
Old Jun 29, 2007 | 05:40 PM
cossiegreg1's Avatar
cossiegreg1
Default just changed my....
fuel filter. old one looked like it hadnt been changed in years.cant half feel the difference.much more responsive.
If anyone hasnt changed theres yet,i recommend you do.Only takes a matter of 10 mins.
I was emptying the fuel that was in the old one and it was black rotten and full of shit.
p.s has anyone noticed how much optimax stinks compared to normal u/leaded. been in the shower and i can still smell it on my hands
Old Jun 29, 2007 | 05:49 PM
PSL's Avatar
PSL
I had mine changed on it's last service and noticed the difference straight away too
Old Jun 29, 2007 | 08:39 PM
And me, when I changed it it had a date written on it and was 12 years old, went better after, way better off boost but on boost the same.
Old Jun 29, 2007 | 08:57 PM
shanemc's Avatar
shanemc
changing mine next week,along with fitting a group a coil,looking forward to seeing the difference
Old Jun 29, 2007 | 09:50 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
You wonder why they get left out on a service, for all they cost and take to fit too! Is it becuase its hidden under the rear end u think? ive had my RS turbo 4yrs and its done about 1000 miles and had 2 filters!
Old Jun 29, 2007 | 09:51 PM
costina's Avatar
costina
Live long and prosper!!
Done mine last month along with a 044 pump and one of Stu's adaptors
Noticed the difference and now its not my daily driver i can drive it properly
Oh and a fuel pump rewire 14 volts on the secs at 850 rpm
Old Jun 29, 2007 | 10:13 PM
Well i changed mine cause it was causing a fault with my car. My car used 2 start drive for about 5 mins then cut out leave it another 5 mins n it wud start. Changed my fuel filter n its beet sweet ever since. Mine had a date on the side from 1992 but the car came with a full service history.
Old Jun 30, 2007 | 06:22 AM
Mine too had full history, amazing how some of the parts even fitted a cossie when I checked part numbers.
Was owned by a guy from Bristol street motors, receipts were for nearly every ford made, ie the history was a load of crap.
I don't ever take any notice of history anyway so was not bothered, just nice to know there are people like that out there.
Old Jun 30, 2007 | 07:35 AM
Well i will know for next time, n take no notice of the service history
Old Jun 30, 2007 | 07:42 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Super Unleaded has more benzine in it, that's what stinks. And that's what's really bad for your health, so don't breath the vapour. People who work at petrol stations get cancer, particularly Lukemia more often, it's the smelly stuff that causes it.
Old Jun 30, 2007 | 12:19 PM
cossiegreg1
I had mine filter since last year. its just one of them jobs i kept putting off and putting off.i think its mainly because its underneath. but i will be definatly changing it every other service now.
Old Jun 30, 2007 | 12:20 PM
cossiegreg1
didnt know that learn summit new everyday
Old Jun 30, 2007 | 12:36 PM
AndyPen's Avatar
AndyPen
Mine has just been changed but resealiing with new copper washers was a pain as the banjo's must be distorted a bit... took 3 attempts to seal it and petrol went everywhere - take care to have an assistant to check
Old Jun 30, 2007 | 01:31 PM
shanemc's Avatar
shanemc
Originally Posted by costina
properly
how do you go about rewiring the pump?did a search and couldnt find any details.wouldnt mind doing mine now that its up on axle stands at the min
Old Jun 30, 2007 | 01:45 PM
mechanic28's Avatar
mechanic28
i am impresses u managed to get it to seal first time always find mine a pain in the ars to seal again
Old Jun 30, 2007 | 01:57 PM
costina's Avatar
costina
properly
Use the original feed Black/red trace to power another 40 amp relay in the boot and a live fused feed from battery(i used 42 amp cable) the biggest u can get into a yellow crimp...i also used the same cable from relay to pump also used the same 42 amp in black to earth relay and pump to chassis..
Old Jun 30, 2007 | 02:42 PM
28/030 is absolutely ample, delivers 17.5 amps continuous, and will go in blue connector, but don't use connectors solder and heat wrap then tape, otherwise moisture WILL get in.
It is easy to get the washers to seal, they go hard with age so just reanneal them by heating to cherry red with blow torch then drop in old oil, this will make them nice and soft again.
PLEASE DON'T HEAT UNDER THE CAR!!
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
