a close shave.....
Old Sep 23, 2004 | 11:02 PM
PGT's Avatar
PGT
Default a close shave.....
took the car to msd for mapping - they wouldn't do it. it had no oil pressure - not a sausage!!!!!
stripped the sump off, removed the pump (ok) then pressurised the oil gallery that the pump would normally feed, with a drill pump. the oil came pissing out the drain hole from the cover that holds the distributor/oil pump jack shaft. the bottom gallery plug had come loose and full oil pressure was simply coming out the gallery into this area then back to the sump.
checked the shells and crank -ok!!!!!
DONT BAN IMA - every topic with ima in is entertaining (and has lots of responses) pitty some folks get so wound up by him
Old Sep 24, 2004 | 01:08 AM
Daveyraveygravy's Avatar
Daveyraveygravy
Very lucky mate
Old Sep 24, 2004 | 07:11 AM
SteveB's Avatar
SteveB
That could have been sooooooooooooo expensive...
Old Sep 24, 2004 | 08:37 AM
foreigneRS's Avatar
foreigneRS
Testing the future
bet you'll be fitting an oil pressure gauge next?
lucky escape
Old Sep 24, 2004 | 08:53 AM
Ian2wdsaffcos's Avatar
Ian2wdsaffcos
Lucky man!! Good job Stu & Kenny are so thorough!!
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
`spotty
Sep 25, 2015 11:41 PM
pabloXR
Sep 21, 2015 12:42 PM
