2wd Cosworth camber castor toe angles height etc.. UPRATED??
Old Jun 28, 2007 | 08:04 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default 2wd Cosworth camber castor toe angles height etc.. UPRATED??
The car:- 2wd Cosworth
Mods:-
Adjustable TCA's
AVO Coilovers
I would like to know the best settings for the above two items for a road and also some track sessions going quick in straight line but needs to hold the road for bends and twists.
Future mods will be some sort of adjustable rear end. I would like to fit Mag works rear end but need more info on what brakes are needed? If a std type exhaust will fit and clear the mag arms? How would you have a handbrake other than hydrolic? + Anything else that could effect the fittment.
Any helps would be great Thanks in advance.
Old Jun 28, 2007 | 08:06 PM
rapidcossie's Avatar
rapidcossie
Mike?
Old Jun 29, 2007 | 07:04 AM
Mr RS500's Avatar
Mr RS500
There are so many things to take into account
wheel and tyre size , for one
What you need adju, TCA"s for is to get more neg, camber , if you go too far then you will just scrub the inside of the tyre of in no time at all but will corner great
The man setting the car up shoud have a good idea how far to go to make it useable on the road
I think my escoss had about 3 degrees extra neg camber ,, you dont need a lot
Old Jun 29, 2007 | 06:08 PM
Versus_Creations
Ask me a question!
Spent all day today getting the settings right. Took a few times before it felt right on the bends.
Also new tyres fitted 205/40/16 Toyo Prada
Just need to sort out the rear beam setup now..
Old Jul 2, 2007 | 05:29 PM
funkyboozer's Avatar
funkyboozer
Im just about to fit adjustable TCA's to my 2wd saph. Does the tracking need to be re-calebrated every time you alter the camber?
Old Jul 6, 2007 | 11:53 PM
whoopty's Avatar
whoopty
yes every time you adjust the camber it knocks the toe out
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
