Quick power loss percentage question
i dont know the exact words to ask this question but heres a try
i hope you get it...
i know Audi quattros lost around 22% between the engine hp and wheel hp..
so what is that loss in a escos?
80 bhp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! somthing needs sorting out there then!! even with 4 x4 taken into consideration--------------------
so my small turbo kicking out 280/290@the wheels should be 360/370at the flywheel-using your calcs-------??
Actually if you work it out as a percentage (like it should be), then your car would be closer to 415 at the fly. But it mainly comes down to the rolling road operator and how they calculate the figure. They are notoriously innaccurate for working out any kind of figure, so just be happy with what you have at the wheels.
Also my car isn't chipped so 280 BHP is a joke in all honesty.
If you go on the MLR you will see some people in their sig mention the wheel HP, most Evo's seem to loose the same amount if i remember corerectly. Could be wrong.
As Tabetha said 2wd is the way to go.
Originally Posted by tabetha
The rolling road operator does not calculate the loss the run down does, it's why they do one.
it`s all relative realy, it can vary from roller and transmissions ( a staight cut box will have less losses than a helicoil cut gear set up )
i lost 70 bhp on a 450 bhp Escort ( works out @ 18% loss approx ?? )
not some thing you should worry about unless there is a problem or you are searching for numbers......
a dyno / rolling road should only realy be used to check the set up is working correctly and safely..........
a 32% loss dose sound a bit excessive from a 250 bhp motor ????
andrewmctiernan
Sep 8, 2015 03:05 PM
