idle speed adjustment on a green top
Old Jun 26, 2007 | 05:28 AM
BEN FRST's Avatar
BEN FRST
Default idle speed adjustment on a green top
How do i pick the idle speed up a bit on my car its a j plate green top on most other cossie engines they have a idle screw on the throttle body. But this one does'nt seem to have one. There must be some adjustment somewhere surely
Old Jun 26, 2007 | 08:27 AM
foreigneRS's Avatar
foreigneRS
Testing the future
as you say, there should be 2 ways to adjust the throttle.
the first is to set the plate angle at rest with a screw, and then there is a tapered bypass screw to let air past the throttle plate. these should be set with the ngine up to running temperature, but no electrical load on it (fans not running etc) and the ISCV unplugged
then of course, the Idle Speed Control Valve should do it's stuff when the engine is cold and when loaded
Old Jun 26, 2007 | 08:48 PM
CosKev3's Avatar
CosKev3
Default Re: idle speed adjustment on a green top
The 4x4 screw is recessed inside the throttle body,and usaully seized solid
Different design to the 2wd one with the lock nut set up
jessie_rs
11
Jun 3, 2019 04:57 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Bailes1992
Aug 16, 2015 07:14 PM
dal3door
Aug 13, 2015 06:55 AM
Zoggon
Aug 10, 2015 10:39 AM
