What Power For My Spec? (With Results) Discussion welcome
Old Jun 23, 2007 | 06:11 PM
BigErn's Avatar
BigErn
Default What Power For My Spec? (With Results) Discussion welcome
Had my car on the rollers today for a power run. Results were not what I expected. (Not saying in a good way or bad way)
My spec is.....
2wd Saff.
Standard comp.
BD10s.
Double valve springs.
Ported & polished head.
803 injectors.
3 bar map sensor.
T34 .55 with 360 bearing and cut back blades.
4x4 intercooler.
22psi peak.
20psi held.
Car was rollered in 3rd gear. I always thought 4th was the gear to use?
Anyway your opinions and guesses please....
Ill post my results later.
Cheers, Ian.
Old Jun 23, 2007 | 06:17 PM
Dicko&Vacant's Avatar
Dicko&Vacant
id say about 320-330 ish but i know what power you got i know motorscope run 4x4s in 3rd for some reason and 2wds in 4th
Old Jun 23, 2007 | 06:18 PM
sbd16v's Avatar
sbd16v
the reason they use 4th gear is its closest to 1:1 ratio gearbox to engine
Old Jun 23, 2007 | 06:19 PM
dave cos4x4's Avatar
dave cos4x4
same as above.
you could easy go for a lot more boost,well enough so the greens don't max out
Old Jun 23, 2007 | 06:20 PM
Fiecos Dan's Avatar
Fiecos Dan
a true 330 bhp.
If it was dyno'd on a DD RR in dyno power mode, 3rd gear is correct.
Old Jun 23, 2007 | 06:22 PM
Miller 3's Avatar
Miller 3
Old Jun 23, 2007 | 06:25 PM
Ollie.'s Avatar
Ollie.
Old Jun 23, 2007 | 06:33 PM
lawnsy's Avatar
lawnsy
same as above.
it was running more boost but it had to be turned down as it was running lean....
Old Jun 23, 2007 | 06:34 PM
BigErn's Avatar
BigErn
same as above.
Had it peaking 26 and holding 20 and it was leaning at top end, plugs were white.
I want bigger injectors and more boost.
Old Jun 23, 2007 | 06:35 PM
BigErn's Avatar
BigErn
lawnsy beat me to it. ^^^^^^
Old Jun 23, 2007 | 06:37 PM
lawnsy's Avatar
lawnsy
well mine run today just before ian's....
comp around 7-0.1
grays t34
l&b bottom end
std head and cams
32psi
and it done 335.1bhp in a 3rd gear run and for some reson it would only get a 26psi boost spike.....i asked him to run it in 4th to try and get a higher boost spike but he said it would make no odds
Old Jun 23, 2007 | 06:42 PM
Fiecos Dan's Avatar
Fiecos Dan
If it werent hitting full boost, Then it wasn't loading the car up fully.
Which in turn will give a less bhp figure.
Old Jun 23, 2007 | 06:45 PM
Miller 3's Avatar
Miller 3
comp around 7-0.1
grays t34
l&b bottom end
std head and cams
32psi
Should have made more than that surely
Old Jun 23, 2007 | 06:48 PM
lawnsy's Avatar
lawnsy
not realy bothered at the end of the day its what it goes like on the roads not the numbers.......
and i left 2 nice big black lines out of the ind est....
Old Jun 23, 2007 | 06:50 PM
BigErn's Avatar
BigErn
So did I, and some wiggly sideways type ones too.
Old Jun 23, 2007 | 06:51 PM
Miller 3's Avatar
Miller 3
Go on fella
Old Jun 23, 2007 | 06:58 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
everyboby will moan all day about R/R graphs.......................mine only held 25psi.......................made 420bhp......................."not on a standard head".....shock horror........................it holds 27/28psi on the road.................if it drives good.................fook the graph...........
Old Jun 23, 2007 | 07:00 PM
BigErn's Avatar
BigErn
Im only bothered that the fuelling etc is ok and its not going to melt.
Anyway it drives ok still, feels quick and is pretty responsive.
This is what I got.
The fella said they shut the throttle off when power starts to drop, but when he actually looked they were shutting off when the power was still climbing.
Old Jun 23, 2007 | 07:03 PM
Fiecos Dan's Avatar
Fiecos Dan
Did you get a AFR and boost plot too?
Old Jun 23, 2007 | 07:11 PM
lawnsy's Avatar
lawnsy
yip but for some reson the computer would not print that page so we have to call back for them
Old Jun 23, 2007 | 07:19 PM
Fiecos Dan's Avatar
Fiecos Dan
Make sure you get them mate, as gives important info for references.
Old Jun 23, 2007 | 08:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Suprised it only made that
You had good torque, almost 350lb/ft
Maybe a 500 type intercooler might help a bit as well.
Steve.
Old Jun 23, 2007 | 09:16 PM
col cos1's Avatar
col cos1
i made 456bhp today at 25psi
Old Jun 23, 2007 | 09:22 PM
Fiecos Dan's Avatar
Fiecos Dan
What ACT's were you seeing?
did he fit the RR ACT sensor on your car?
Old Jun 23, 2007 | 10:22 PM
costina's Avatar
costina
Live long and prosper!!
Wheel or fly figure seems a bit low imo
Old Jun 23, 2007 | 10:47 PM
BigErn's Avatar
BigErn
Thats flywheel figure.
Old Jun 23, 2007 | 10:54 PM
BigErn's Avatar
BigErn
Boost plot and at the wheels figure.
Old Jun 23, 2007 | 11:03 PM
Nash's Avatar
Nash
Cake lover!
DD rollers dont give ego boosting results, just look at the Results from the APT day. Thats why my car will run on DD once its in and mapped.
Good result Col Whats new then?
Old Jun 23, 2007 | 11:06 PM
lawnsy's Avatar
lawnsy
Steve.
ive got a 500 cooler
Old Jun 24, 2007 | 05:52 AM
Fiecos Dan's Avatar
Fiecos Dan
Its only hitting 20psi, and drops to 17psi.
Old Jun 24, 2007 | 05:54 AM
They use a lower gear as it pushes UP the power figure, due to lower speed at the wheels and lower friction between tyre and roller.
Old Jun 24, 2007 | 07:27 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
A typical response when your claimed million bhp dont get proved on the rolling road. Remember all Cossies feel fast until you go in a fast one.
Old Jun 24, 2007 | 07:59 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve.
I was talking about BigErn's
Steve.
Old Jun 24, 2007 | 08:40 AM
pete mcrash
...........what do u mean..???...........i was happy as fook to get over 400 on my spec engine.........
Old Jun 24, 2007 | 09:48 AM
coswurv's Avatar
coswurv
This is what I got.
Bloody hell BigErn G4 made nearly 40bhp more than that on a standard lump and turbo something must be a miss there
Old Jun 24, 2007 | 12:18 PM
BigErn's Avatar
BigErn
Lawnsys was well down on the boost on his graph too, wonder why??
Old Jun 24, 2007 | 12:20 PM
BigErn's Avatar
BigErn
MadRod I was there when Pete got 420bhp, its not a "claimed" figure.
Old Jun 24, 2007 | 05:27 PM
Fiecos Dan's Avatar
Fiecos Dan
RR road loadings is the issue.
BigErn, What ACT's are you seeing?
Old Jun 24, 2007 | 06:02 PM
ESCYSCOTT's Avatar
ESCYSCOTT
yeah but these cars are fast around corners too pal, not just in a straight line down an airfield
Old Jun 24, 2007 | 11:37 PM
BigErn's Avatar
BigErn
PMSL @ ESCYSCOTT
