Is this worth buying?
oh boring infomation time
did you know that when you do a head gasket its recomended that you get the rad flow checked and change the thermostat
due to these being reasons for it to let go,,,,, yet most people dont even know this
Originally Posted by OrionRST200bhp
you laugh but if that IS a copper core rad then its the best rad material you could get
just cause its not shiney dont mean its crap
actually change that,, just cause its not got a pro alloy sprayed onto it dont mean it must be shite
did you know what pro alloy AND radtech both buy there rad and intercooler cores from a company called nissens who make most of the rads in the country including standard rads for car companys aswell as aftermarket
the end caps are the ONLY difference,,, cores are rhe same,,,, btw i speak to nissens about 10 times a day when i order rads for them and he recomended pro alloy for a frst rad i was trying to get due to wayne being a dam good lad and he said hes welding and fabrication is spot on and is proud to deal with him
so guess you could say pro alloy ARE good,,,, or waynes a fucking big customer of hes these days
timsrs
22
Sep 24, 2015 08:14 PM
cossie09
Sep 10, 2015 06:56 PM
i have one under a bench
