cossie not firing....
Old Jun 22, 2007 | 06:33 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Default cossie not firing....
hi guys ive just finished putting my car back together after changing the tappets and cam belt. but it's not firing. the cams are timed up and the crank is timed up but i think i may have the other cog 1 or 2 teeth out. should it still fire?HELP.
Old Jun 22, 2007 | 06:46 PM
abdr500's Avatar
abdr500
did you make sure the rotor arm was lined up aswell in side the distrubutor ther is a littel notch on the rim of the dizzy.... and the bottom crank pully have a grove in it THATS NOT to be used to time it up
if you have done it right then it couldbe that the oil has to full up in the hydrolic lifters does it sound like its turning over faster than normal at all
Old Jun 22, 2007 | 06:53 PM
OrionRST200bhp
I forgot to check the rotor arm but yea it does seem to be turning over quite fast.
Old Jun 22, 2007 | 06:54 PM
L33 BYT's Avatar
L33 BYT
Quite fast? What like compression is down?
Are the tappets New or second hand?
Old Jun 22, 2007 | 06:57 PM
abdr500's Avatar
abdr500
OrionRST200bhp
cheack the dizzy m8 and re time it so you can see how far out the dizzy is if that ok then i would say the lifters need time to fill up had this happen to me many times
Old Jun 22, 2007 | 06:58 PM
Graceland's Avatar
Graceland
Team HOTHOT!
OrionRST200bhp
Where abouts are you? if you are in West Yorkshire, I'll come and time it up for you
Old Jun 22, 2007 | 07:00 PM
OrionRST200bhp
im about 400/ 500 miles from you mate i live in north devon haha
Old Jun 23, 2007 | 01:45 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Arse. I'm not trailing that far
Old Jun 23, 2007 | 02:40 PM
Yes it will still fire, if you mean spark, but not when it is any good!!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
