ST24 - Cambelt Change??
Old Jun 22, 2007 | 06:32 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
Default ST24 - Cambelt Change??
My mate has bought an ST24 and is going to get the camblet checked as a precaution, and get it done if needs be. How much is he looking at for the work say if he goes to main dealer, and also independent etc
Cheers in advance
Dave
Old Jun 22, 2007 | 06:42 PM
SteveB's Avatar
SteveB
I'd say 100% that the cambelt would be 100% spot on with no problems at all
Old Jun 22, 2007 | 07:21 PM
jpbaginski's Avatar
jpbaginski
No cambelt fitted on the ST24>>>>>
Old Jun 22, 2007 | 07:27 PM
Csm's Avatar
Csm
No cambelt fitted as its chain driven
Old Jun 22, 2007 | 07:31 PM
coco16i's Avatar
coco16i
Got to agree with you there mate...... have never in my time seen a cambelt give bother on one of these
In case you aint sussed it yet mate the V6 mondo's are all chain driven and dont have a timing belt
Old Jun 22, 2007 | 07:37 PM
Csm's Avatar
Csm
The precation u need to check tho is the waterpump as the original one has a plastic impellor that breaks and once you realise it its too late and its roasted bigtime
upgrade with a metel impellor pump and its fine , think u can get em for around the £45 iirc when i had my st24
Old Jun 22, 2007 | 08:30 PM
BigMouthBillyBass
I was only relaying information i was given
Cheers for the responses though
Anything else worth checking on a 65k car??
Old Jun 22, 2007 | 08:40 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
I'm glad he's bought it dude. I can;t wait to talk him into letting me drive it
Old Jun 22, 2007 | 09:40 PM
coco16i's Avatar
coco16i
Just the usual Mondeo faults really mate, wishbone bushes,broken coil springs,check the brakes pipes at rear of the car especially where they run up alongside the fuel tank as they all rot there !!!!
Old Jun 22, 2007 | 10:15 PM
BigMouthBillyBass
I just saw him on TV actually....
"Knock-Off Nigel"
BigMouthBillyBass
Cheers mate, will check the above points
Old Jun 23, 2007 | 07:04 AM
There was trouble with the chain tensioners resulting in failures as the oil pressure keeps then in tension, quite sure but not 100%.
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
