Seat Belts
The retracting mechanism is getting old and require a helping hand every now and then. I was thinking of replacing all the 3 points belts. Are the escos one same as the 3door MK V escort? or are they special ones? are they still available? Cheers in advance
I would say 99% they are the same, maybe check part numbers at fords.
If you have difficulty doing this PM me and I'll do it on monday for you, as I don't know what the situation is like in HK with FORD ?
thanks for the offer tabetha
The Ford over here is under the Sime Darby Group, and they sold 2 Focus ST so far since its launch. Not promising at all.
If you could be so kind to provide me with the Finis codes, so that I can confirm it with them. that would be great
