non starter
Old Jun 20, 2007 | 12:16 PM
lewis_lisa's Avatar
lewis_lisa
Default non starter
o.k guys my bros saph 4x4 wont start now was running fine then fuel pump wnt he changed it over then car ran well again now it wont even start and when it does it just runs lumpy and backfires hes orderd a new set of plugs,leads and dizzy cap also hes been having some probs wae fuses melting i cant offer him much help as i dont know anything bout cossies.
just wants all these probs sorted out once and for all if thats possible as the show season is nearing its peak cheers for any help
Old Jun 20, 2007 | 12:19 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Fuses melting? Might be time to replace the loom, but don't take my word for it.
Old Jun 20, 2007 | 03:11 PM
Don't replace the loom.
You most likely have two seperate problems.
Check the CPS connector by doing the wiggle test, whilst running, these can and do give what you describe, as do lots of other things but cheap/free checks first.
Fuses melting, are a sign of a short or overloaded circuit unless it is the engine cooling fan circuit ?
Old Jun 22, 2007 | 12:56 AM
lewis_lisa's Avatar
lewis_lisa
fuses now sorted as it was the fan circuit will get the cps connector checked asap
cheers for that
Old Jun 23, 2007 | 09:26 PM
lewis_lisa's Avatar
lewis_lisa
o.k guys tried all this out now and was checking the spark from coil its an unhealthy red/orange instead of blue tried diff coil and no joy changed leads and plugs and dizzy cap also cleaned up cps and no joy really struggling on this 1 seems to be electrical
cheers lads
Old Jun 24, 2007 | 05:12 AM
Look closely at the phase sensor wires to see if disintergrated(inside dizzy).
I would not worry about the colour of the spark, so long as there is a spark.
As you have recently changed the fuel pump, how many miles has it done since ?, have you changed the fuel filter lately.
As the problem started since the pump change, it may be loads of air in the system but this ould cause surging, mine revved up to 3000rpm on it's own after I did mine, which was over ten years old.
Check the voltage at the pump anyway.
Also not meaning to be rude double check the firing order as backfiring is normally ignition timing related.
Just a few ideas
Old Jun 26, 2007 | 12:45 AM
lewis_lisa's Avatar
lewis_lisa
Just a few ideas
thanks once again will let you know how i get on
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
